2 wheels and tires for sale plus the special lugnuts required , they are 7/16" thread. Gorilla lugnuts has these if you need 1/2". They have the inserts in now for 4 3/4 bolt pattern. Tires are new 205 75 14 with about 20 dragstrip passes, the sides have been smoothed over to remove the lettering. These are made for drum brakes but I have on my car now with gm disc. I ground on the calipers some and used a 1/8 spacer and I also installed longer studs in my rotors. I've been over 100 mph at the track and no problems with vibration or brake interference. Torqued at 100 ft lbs and no problems coming loose either. I'll include the spacers if needed. ET II wheels are a steel rim with an aluminum center . I don't have any centercaps and has a few broken screws where they mount. I left the original paint and patina intact but are nice enough could be restored. 250 plus shipping which will be heavy . prefer local pickup but will ship.
I have a 3rd wheel that is 14 x 6 to add for 50 if you buy the other ones., the one in the pic above, the other 2 are 14 x 5 because they were narrowed to clear disc brakes. can pull tires. tires are less than 2 years old with maybe 10 miles on them since all I do is race at the track.
