i have a 2-1 intake manifold and i was wondering you guys had any pictures to help me out. you see i need to come up with a way to run my linkage an im not sure how. thanks for the help!
Depending on your throttle set up on the carb, run a rod from the cable attachment point on the front carb bck to the rear one, or if part of it sticks down below the shaft you can run a rod down there. Just make it where it can swivel as you operate the throttle.
You have to give people more information to get a good answer. What make, style of engine and carbs are you using. There is a good chance that someone has done the same thing and may have pictures to help but they have no idea that they can help you.
