1970's hurst competition plus shifter rebuild
Discussion in 'The Hokey Ass Message Board' started by OldoginMd, Apr 18, 2013.
  1. OldoginMd
    OldoginMd
    I have a 1970's hurst competition plus shifter #369684 that I need to take apart , does anyone know where I can get a blow up of the pieces ?
    Thanks
  2. Don's Hot Rods
    Don's Hot Rods
    from florida
    If someone doesn't have what you need just take lots of pictures so you can refer back to them for reassembly. There isn't a lot to these shifters, mostly you will just be cleaning it up and replacing a few plastic bushings and rub plates (maybe). If you watch how it comes apart and take the pictures you should be ok.
    Don
  3. Any idea what its out of? Any general paperwork that comes with any comp plus shifter should work. PM if you can't find one, I probably have one still in the box with my shifter on the shelf.
    Bob
  4. 65ssnova
    65ssnova
    from Tulsa OK
    There's a guy on YouTube that has a video on the rebuild process, I used it and it helped alot.
  5. OldoginMd
    OldoginMd
    Thanks
    I need to take the guts out of it to find out why I can not get it in reverse .
    I will try to find the vidio on utube
    Thanks again
  6. 327-365hp
    327-365hp
    from Mass
  7. kasselyn29
    kasselyn29
    Hey on the not going into reverse I have one in my model lsr car and u have to push down to get it to go in reverse. I thought there was a problem with it and started to take it apart then figured it out.Also it helps to have it bolted down to make it work. Hope this helps.
  8. Moon Rocket
    Moon Rocket
    from GA
    If your going to the trouble of taking it apart, atleast get a set of new metal bushing instead of the plastic ones.
  9. OldoginMd
    OldoginMd
    Thanks for the links 327- however I do have one more question to all ..what is the shifting patern for reverse ? I managed to get 3 and 4 but no reverse ....there does not seem to be any delete ...ie; push down and .....
    is it all the way to the left and down ?
    Thanks
    Oldog
  10. Moon Rocket
    Moon Rocket
    from GA
    I believe you will find it to the left and forward. :rolleyes: Unless you have a uncommon trans.
  11. greg32
    greg32
    from Indiana
    About ten years ago I sent an old super shifter to Hurst for a rebuild. Had a Nevada address, think it was 75 bucks. Call Hurst customer service if interested. It was like new.
  12. OldoginMd
    OldoginMd
