1967 Dodge Dart slant 6 to V8
Discussion in 'New to the H.A.M.B.? Introduce yourself here!' started by Cobrajet, Nov 20, 2009.
  1. Cobrajet
    Cobrajet
    from NY
    Can anyone tell me the details of swapping a 225 Slant 6 for a 440 V8... the vehicle in question would be a 1967 Dart GT convertible... auto trans on the column. Thanks!!
  2. PegLegStrick
    PegLegStrick
    Try the search button at the top of the page.............
    Welcome from South Georgia
  3. Cobrajet
    Cobrajet
    from NY
    Yeah, tried that... no luck there.
  4. PegLegStrick
    PegLegStrick
    Might try posting a question in the General discussion board.....
    Get a lot more responce there
  5. moparmonkey
    moparmonkey
    from NorCal
    A '67 is a little late for here, I'd try over at http://www.forabodiesonly.com/ or http://www.bigblockdart.com/ .
    Its a fairly straighforward swap and is done quite a bit. Motor mounts are sold for big block conversions, you'll also need a set of headers specific to that swap (also available) and a new transmission to go along with it since the /6 bell wont fit. For a 440 you'll also likely need a new rear end, since I'm sure you probably have a 7 1/4 in that Dart with the /6.
    Its been covered in depth at both the sites above. :D
  6. 440shawn
    440shawn
    Welcome from Illinois. Sounds like a great motor swap
  7. Big Dad
    Big Dad
  8. Cobrajet
    Cobrajet
    from NY
    Thanks for all the help guys!! I appreciate it.
  9. jerricuda
    jerricuda
    from Idaho
    I have done a dozen of these swap but have probably fogtten lots. Pretty straight forward swap. Either swap out with aftermarket motor mounts (slant six is taller on one side of K frame) or back off torsion bars all the way remove and replace K member for a v-8 one (all are the same but you need to use the right motor mounts to match K member as there are two different styles of motor mounts). All electronics will work on either 6 or 8. Radiator swap to match outlets of motor. There ar two different styles of upper control arms but both will fit body, just be sure that you use same spindle that came with upper a arm. Tranny will be spicific for 6 or 8. 6 cylinder torsion bars are smaller diameter but drag racers like this for weight transfer. Any A body torsion bars will fit. hope this helps
  10. Idlzruf
    Idlzruf
    Moparts.com is a great place with tons of info. I got a mid 70s dart and swapped k memebers and dics brakes.Bigblockdart.com should have links to conversion mounts
  11. vernmotor
    vernmotor
    from ohio
    I have a v-8 k-member for a 67 dart if you want to do it that way.
  12. hemidart
    hemidart
    I specialize in the MOPAR ENGINE SWAPS, I HAVE THE ENGINE MOUNTS, THE CORRECT HEADERS, NO K-MEMBER SWAP, can use your current K-MEMBER.
    I also have the correct A-BODY 8.75 REAR END SET-UP FOR SALE
    You car will NOT BE MODIFIED, in any way, so you would lose value
    MOPAR CHARLIE
    727-271-5068
  13. SLCK64
    SLCK64
    A lil late of a car for HAMB, but looks like you are getting help!
