1966 Ford F100 build
Discussion in 'The Hokey Ass Message Board' started by Randzz75, Aug 3, 2012.
  1. Randzz75
    Randzz75
    Decided to go with a rear roll pan instead of a bumper on a purely financial reason.....pan was way cheaper than a bumper!
  2. Randzz75
    Randzz75
    You can also see in that picture the start of the body line that im building on the bed
  3. Randzz75
    Randzz75
    More body work, and she's sitting at the stance she'll have for a while....aired out
  4. Randzz75
    Randzz75
    Almost ready for a coat of filling primer
  5. Randzz75
    Randzz75
    need to do some alignment work on the hood
  6. Randzz75
    Randzz75
    I did get to drive it for a week or two before I started the body work
  7. Randzz75
    Randzz75
  8. Randzz75
    Randzz75
    guess i should show a couple things that happened before I drove it! Here's some of the cuts I had to do to make the exhaust work with its low stance. I also had to cut 1" out of the header before the collector on the drivers side
  9. Randzz75
    Randzz75
    here's where the battery found a home, routed all the cables through the bottom
  10. Randzz75
    Randzz75
    And the Viair 480 that fills my tank
  11. Randzz75
    Randzz75
    Here's the whole bed....Ive since added a second viair compressor, bed bracing under the floor to the frame, large wheelwells and all of the relays and fuses for the airride sit in the corner by the battery
  12. Randzz75
    Randzz75
    Ive also gotten rid of the big fuel cell in favor of an thin aluminum RCI fuel cell, Im also thinking of doing a false bed floor covered in black stained hardwood planks with recessed doors to access the battery, airride and fuel filler....Opinions? And I have thick skin so I can take the harshest of opinions!!!
  13. j-dogg
    j-dogg
    I really like what you did with this truck. Looks good.
  14. 510madmav
    510madmav
    Looks cool, I dig those trucks.
  15. Randzz75
    Randzz75
    So here's what I traded my 400m motor and 3 speed tranny for
  16. Randzz75
    Randzz75
    bondo is flying.....would love to learn how to lead instead of this crappy plastic filler
  17. Randzz75
    Randzz75
    Thanks guys!
  18. Randzz75
    Randzz75
  19. Randzz75
    Randzz75
    Decided to go different on the interior, shaved the vents in the top of the dash and got rid of the stock speaker cover
  20. Randzz75
    Randzz75
    trying to make it all 1 color
  21. Randzz75
    Randzz75
  22. Randzz75
    Randzz75
  23. Randzz75
    Randzz75
    Shaved a couple of the knob holes below the gauges, just the ones i wont use, also cut 6 inches out of the length of the steering column to give me more room
  24. Randzz75
    Randzz75
    here's the first choice in color, 70's corvette steel cities grey
  25. Randzz75
    Randzz75
  26. Randzz75
    Randzz75
    painted the interior, not sure if I like it, was expecting more grey
  27. Randzz75
    Randzz75
    put it back together to try to decide if I like the color
  28. Randzz75
    Randzz75
    You can see my 1st try at engine turning on my switch panel I made for the airride, also a good shot at how the tach looks behind the smoked plexi-glass
  29. A Rodder
    A Rodder
    I love it.
    I seen where you mentioned the body line you put in the bed, but don't see it. What did you do?
  30. Randzz75
    Randzz75
    also a good shot at all the chrome pieces I had powder coated gloss black on the inside of the cab
