1966 Ford F100 build
Discussion in 'The Hokey Ass Message Board' started by Randzz75, Aug 3, 2012.
  1. Randzz75
    Randzz75
    Thanks and even though Im a Ford guy, I can appreciate how easy the Chevy stuff goes together:eek:
  2. Randzz75
    Randzz75
    Definitely all Ford from the firewall back!!!!!
  3. Randzz75
    Randzz75
    Heres the stance after the front clip and step notch, before the links and the bags in the back
  4. Randzz75
    Randzz75
    heres some better pics of what I did with the bottom front bar brackets
  5. Randzz75
    Randzz75
  6. Randzz75
    Randzz75
    Heres the initial cut in the bad to clear the notch, had to cut further to clear full suspension
  7. Randzz75
    Randzz75
    and you can see where i was thinking about putting the stock gas tank, but scrapped that idea once I saw what was inside
  8. Randzz75
    Randzz75
    Got the front end mocked up, while I was working on the rear suspension
  9. Randzz75
    Randzz75
    And I forgot about my new shoes in the above pictures
    believe it or not but they are radial tires with port-o-walls on 2 stock powdercoated 66 ford wheels and 2 summit powdercoated steelies
  10. Randzz75
    Randzz75
    welding in the bag mounts.....never mind the ugly booger welds.....amazing what a grinder can hide
  11. Randzz75
    Randzz75
    got the bags in and plumbed, extending the bag mount to make room for the rear shocks
  12. Randzz75
    Randzz75
    shocks in but they are pretty short so i'm going to have to think of something else down the road, but they'll work for now
  13. Randzz75
    Randzz75
    Finally started some body work...there was a ton of bondo on this baby, and a ripped out tailight section, got it put back in and a little filler on it
  14. Randzz75
    Randzz75
    Time to do some shaving!!!
  15. Randzz75
    Randzz75
    ready to make some templates
  16. Randzz75
    Randzz75
  17. Randzz75
    Randzz75
  18. Randzz75
    Randzz75
    Trying to keep the heat down
  19. Randzz75
    Randzz75
    Also shaved the hood emblem, antennae hole, and stake pockets in the bed[​IMG]
  20. Randzz75
    Randzz75
  21. Randzz75
    Randzz75
    Im also filling the seam around the top of the cab, smoothing it out, the seam running horizontally down the side of the bed and building a profile like the one on the door, and also filling the seam down the rear corner of the bed
  22. Randzz75
    Randzz75
    my oldest boy throwing the peace sign while doing some garage cruisin'
  23. KustomCars
    KustomCars
    from Minnesota
    Wow ! Looking good! Like it alot!
  24. Randzz75
    Randzz75
    Also shaved the emblems and trim around the sides of the truck
  25. Looks good for you're first time. Just keep learning and if you fuck it up it's only metal and can be fixed.
  26. sanch052
    sanch052
    Nice work, your really motivating me to start working on my car.
  27. Randzz75
    Randzz75
    Trying to get the dash wrapped up
  28. Randzz75
    Randzz75
    Had to scrap the grenade, couldn't get the Lokar adapter to work right. Has anyone else had this problem?
  29. Randzz75
    Randzz75
    Here's the gauge cluster idea I came up with
    I put a 3 3/4 speedo and a 3 3/4 quad gauge into holes that i cut where the stylish circles are in the original 65 dash. I then cut all the guts out of the middle original gauge bracket and replaced the glass with dark smoked almost black plexi glass. I then mounted a tach behind the plexi-glass that's visible when you turn the key on and it lights up
  30. Randzz75
    Randzz75
    Done but think im heading a different direction with it
