Projects 1966 F100 "FE" Powered Project
Discussion in 'The Hokey Ass Message Board' started by TimeWarpF100, Jun 2, 2011.
  1. FEblockhead
    FEblockhead
    I could only hope my 65 looks this good one day. Great build. Best I've seen. Great attention to detail.
  2. TimeWarpF100
    TimeWarpF100
    of course had to build a new gate a bit more secure and private.
  3. TimeWarpF100
    TimeWarpF100
    Ooops, Got side tracked.
    427 Project box finally all in one piece.
  4. loudbang
    Wow you keep pretty busy for one of us "Old guys"
    hendelec likes this.
  5. TimeWarpF100
    TimeWarpF100
    To any who were following this build. Going on 19 yrs since I bought it. going on 11 yrs since I tore it apart for a resto. After spending all that time replacing floor, 427 spot welds drilled out. I had replaced it with a late model floor because that was all that was avail new. Well, after all that the new floor sheet metal was just that modern with a different stamp design and shape. I will use the original box for a matching trailer. I bought another short bed truck removed box then sold rest of truck.
    Finally back on it hoping to finish truck by mid october.
    This is box I am using. Hoping to bang it all straight so zero bondo will be needed.
    j-jock likes this.
  6. TimeWarpF100
    TimeWarpF100
    Interior is bone stock with exception of adding a period correct Stewart Warner Tach I have kept new in box for over 40 yrs.
    Since this tach was made for in dash I used a piece of pipe reducer to make a mount and bracket. Clamped it on like was done way back when with a hose clamp although I did put cork underneath clamp.
    j-jock likes this.
  7. TimeWarpF100
    TimeWarpF100
    undercarriage is pretty much done. Did add a overdrive unit to the c6 to help keep RPM down while cruising @ 80 mph
    Engine compartment now 99% done.
    the 427 FE is up and running.
    The Rechromed mercury script covers came out great! Unfortunately Advanced plating which did them burned to the ground a couple days ago.
    A few loose wires to tidy up. Stock radio has been restored but the exhaust note will by my stereo
    All glass now in
    Trim except antenna is on
    jchav62 and j-jock like this.
  8. TimeWarpF100
    TimeWarpF100
    Many many hours spent restoring the stock hardware. Some is NOS.
    Even found some date coded NOS glass
  9. TimeWarpF100
    TimeWarpF100
  10. TimeWarpF100
    TimeWarpF100
    Even found a unused 1966 Arizona Non Commercial Truck Plate!
    GASSERBOB, jchav62 and j-jock like this.
  11. Old-Soul
    Old-Soul
    Your attention to detail shows. Very clean truck.
    My cousin nabbed this '61 short unibody for a case of beer at the beginning of last summer and thrashed on it all year (with help from his dad, myself and my dad) and made it to grad in June. He too went with an FE, a 390 out of my dad's old Ranger, mated to a '68 Mustang toploader w/ Hurst shifter.
    I swear he has a horseshoe rammed up somewhere though as every step of the way if he needed an item it just sort of materialized haha. "I need headers" boom, a decent set listed on local classifieds that same afternoon.
    Anyway, sorry to hijack and great job on your pickup!
    Special Ed and jchav62 like this.
  12. LB+1
    LB+1
    from 71291
    Art of knowing how you darn well know how! :)
  13. Boneyard51
    Boneyard51
    I feel like a Johnny-come-lately! Just found this thread and went back to the start and followed it all the way through. One word... awesome! Your attention to detail after all you’ve been through , is amazing! As has been said, it’s got to be the most perfect ‘66 Ford pickup in the world. Would love to see it in person, but I live in Oklahoma. Keep on keeping on!
    Bones
  14. TimeWarpF100
    TimeWarpF100
    Thanks for the kind words! Hoping to have box painted and on within 45 days. Just in time for the cooler AZ weather as this truck has the Factory 66 A/C. 66 MPH with the windows down and vent windows pointed backwards . .
    Boneyard51 and Special Ed like this.
  15. 4 pedals
    4 pedals
    from Nor Cal
    Just re-found this thread after a few years. I'm still impressed by the amount of attention to detail. Absolutely beautiful build! I know you've been through personal trials since you started, I hope you are able to complete your dream truck.
    Devin
    TimeWarpF100 likes this.
  16. All I can say is, what beautiful workmanship. Love the 427.
    Bob
  17. TimeWarpF100
    TimeWarpF100
    Not sure how but managed to get the box in primer! Goal was to metal finish and not use filler but ended up using a tad of filler on some pitting on box floor. Lots of pickin n' filin' on bedsides. There were creases at all four corners. Junk 3m gun came apart while spraying and let's just say I will have red primer freckles for years to come!
  18. 34toddster
    34toddster
    from Missouri
    What brand of Red primer did you use?
    Your project is coming along, looks great!
  19. TimeWarpF100
    TimeWarpF100
    It’s PPG. Getting very expensive but started with it so want to finish with it.
    34toddster likes this.
  20. TimeWarpF100
    TimeWarpF100
    Blocking primer on, then blocked every nook and cranny then re-primed. Underside now in color!
    Back on cart to finish up the rest.
    loudbang and Boneyard51 like this.
  21. TimeWarpF100
    TimeWarpF100
    My daily driver 1966 F100 Ranger (factory bucket seats) all options truck has been bare metal for approx 16 months. It’s got caught in quite a bit of rain lately so time to do something with it.
    It’s a 352 with the 3 spd Overdrive Trans.
  22. 4 pedals
    4 pedals
    from Nor Cal
    lookin' good!
    Devin
  23. TimeWarpF100
    TimeWarpF100
    I made these wooden blocks from hardwood to help in sanding the many grooves on top n bottom side of box floor.
    Got the basic shape then used sticky 80 grit paper stuck to grooves then sanded wood for perfect fit. To sand I just reversed. Put sticky on blocks
  24. TimeWarpF100
    TimeWarpF100
    Stampings are different so one groove block goes one way the next grove rotate 180 deg.
  25. TimeWarpF100
    TimeWarpF100
    Picked up some Black SPI primer to go in bare metal truck. Also have new stock Black upholstery for the buckets, new carpet etc.
  26. GASSERBOB
    GASSERBOB
    from USA
    Boy o boy that truck is beautiful. My word . Beautiful craftsmanship. Can't wait till its done. Keep us updated . Thanks. Bob..............
    loudbang and TimeWarpF100 like this.
  27. TimeWarpF100
    TimeWarpF100
    The F100 Ranger looked like this! Drove it for a month or so as joke then it got old so decided to remove stripes. Got a bit carried away.
    There are only 53 total trucks in Ranger Registry so it’s a quite rare truck. Local driving have gotten 22.6 mpg out of the stock 352. The factory Overdrive combined with the 3.25 gear gives final gear of 2.275. The very low rpm TQ of the 352 does wonders. 35 mph per 1000 rpm.
  28. TimeWarpF100
    TimeWarpF100
    It’s been in Arizona since new. One family owned. The 1965 TBird hubcaps were ordered with truck as was the 1965 TBird paint tropical turquoise.
    Paint code on door tag is blank
    It also has the only known center jump seat.
  29. TimeWarpF100
    TimeWarpF100
    Color in pic is amint green not original. [​IMG]
    Original shown in pic. Undecided if it will go Factory color or black. Paint code blank Special order so I can put anything on it.
  30. TimeWarpF100
    TimeWarpF100
    Thanks Bob! Trying to get box painted but getting so much rain. October 1st we had enough rain to be second most rain in October since records were kept. Raining again today. Our annual rainfall is under 7” per yr. we just may beat that for month of October.
