Hot Rods 1966 F100 Farm Truck
Discussion in 'The Hokey Ass Message Board' started by CBurne7, Nov 23, 2020.
  1. CBurne7
    CBurne7
    EDIT: Working on posting photos...
    Hi everyone,
    I've been looking for a 61-66 F100 project for awhile now in order to pass the time while at Fort Hood, TX. I found a solid '66 F100 short bed that I'll have home within the next week to start working on. It's a factory 352, 4-speed 435NP with a granny gear, Dana 60 with factory locking 3.54 gears. It hasn't run in a few years, but according to the previous owner it "ran when parked" for whatever that's worth. lol. It needs some body work, but mostly just bumps and bruises from being used around their property. The tailgate is completely gacked from someone backing into the truck with a tractor. Luckily, because it sat out in the desert it doesn't have very much rust to take care of.
    My plan is to build up a 390 with decent heads, cam, intake, etc. or possibly find an another OT FE motor (in the vicinity of 428ci if you know what I'm sayin), as well as give it a decent hot rod rake, steel wheels and hubcaps, and a 4 speed toploader. Should be fun.
    My main concern is keeping the rust from spreading in the vital areas like the cab corners, mounts, drip rails, bed. Being in TX right now it's not much of an issue, but once I get it back to Baltimore I know I'll be fighting the moisture. I was thinking of just knocking the surface rust off and using a clear primer like some Rust-oleum auto body primer in clear to keep it from spreading. That way until I get it painted I don't have to look at splotches of primer. I'm not one much for the PaTiNa look, but I just want to keep it from becoming deeper rust. Any thoughts on that?
    The Magic Ratchet likes this.
  2. CBurne7
    CBurne7
  3. anthony myrick
    anthony myrick
    A 5 lug Dana is rare.
    Cool
    Deuces, Truckdoctor Andy and CBurne7 like this.
  4. deathrowdave
    deathrowdave
    from NKy
    I have built 3 of these for my Buddy through the years . Need any help contact me, please
    Deuces, VANDENPLAS and CBurne7 like this.
  5. CBurne7
    CBurne7
    Honestly, I'd rather it be a ford 9in, but it's cool in it's different.
  6. anthony myrick
    anthony myrick
    That 60 is geared perfect.
    Lots of support for it.
    I wouldn’t trade it for a 9. But I have a 9 I would trade for it
  7. fastcar1953
    fastcar1953
    Have you tried rubbing compound? Most might come off on hood and top.
    CBurne7 likes this.
  8. CBurne7
    CBurne7
    I'm going to clean up the surface rust on the drip rails, but I'm not sure what the best method to seal them up would be. I'm guessing there's some sort of automotive caulk I can put down on there?
    Also, from what I can tell DJM's dream beams are the go-to way to lower the twin-I-beam front end. I don't want to slam the truck, but want a nice rake. What's a conservative way to lower the rear? I'm really not interested in flipping the axle and doing a C-notch. I need to still use this as a parts hauler truck.
    I've been reading up on different methods. I think the majority of the big patches will come off fine, but I'm more concerned about difficult seams and spots like the drip rails, cab corner, etc., then actually SEALING it so it doesn't come back.
  9. 66gmc
    66gmc
    Most panels rust from the inside out, so if there is rust showing on the outside then its already too late. I would clean out every nook and cranny, then coat the insides of the panels with a good epoxy primer. If your not planning to paint it immediately then using wax oil on all the enclosed areas helps, but it makes a hell of a mess. It looks like the majority of the rust in your photos is just surface rust from the paint wearing thin, rubbing compound works good to clean that off, then Carnauba wax the whole truck, reapply every few months if its sitting outside. Or you could also get your local auto paint store to mix you up some color matched paint and just fog some paint in all the areas that primer or bare metal is showing through.
    CBurne7 likes this.
  10. captainjunk#2
    captainjunk#2
    that would be a $10.000 truck in Massachusetts
  11. deathrowdave
    deathrowdave
    from NKy
  12. CBurne7
    CBurne7
    This is what I'm thinking I'll probably do.
    Right?? lol. There's a reason I looked for a project while I was down here.
    VANDENPLAS likes this.
  13. 51504bat
    51504bat
    X2
  14. CBurne7
    CBurne7
    I read up on that stuff and it looks pretty good. Don’t know what I hadn’t heard of it before. Say I wanted to knock off the surface rust like on the cab corners, what would you recommend I start with?
  15. Callmaker
    Callmaker
    really nice truck,
    CBurne7 likes this.
  16. The Magic Ratchet
    The Magic Ratchet
    The original 352 is a nice jumping off point for a much larger FE motor. With a nominal overbore (.050") you have the standard bore of a 390, add a 390 crank and you are there. With a 428 crank you have a 410 (a Mercury motor built for torque). With aftermarket stroker kits you can go all the way to 445 cu. in. Of course you will need better heads to feed the increased displacement but there are plenty of options, factory as well as (OT) aftermarket.
    Lou Manglass
  17. Gearhead Graphics
    Gearhead Graphics
    from Denver Co
    CLR and buffing compound will go a long ways.
    If you found some color match to fog in over the bare metal that wouldnt hurt.
    Open the kick panel vents on both sides, dig and vaccuum all the crud you can out of them, they will be full, once theyre clean that will help kick panel and body mount rust from happening
    CBurne7 likes this.
  18. Congratulations, love the 65/66 F-100 Ford trucks. HRP
    CBurne7 likes this.
  19. Hotrodderman
    Hotrodderman
    A tailgate up to 72 will fit the truck. I used a 67 on my 64 F100 years ago
    Hotrodderman
    CBurne7 likes this.
  20. bigdog
    bigdog
    I've owned two '65 F100s. nice trucks to drive. That looks like a good one.
    CBurne7 likes this.
  21. Norris McCarty
    Norris McCarty
    Don’t paint it.....That is an honest Texas truck. I know as Ive spent the last 66 years here. Gibbs is good. You just have to apply it regularly.
    CBurne7 likes this.
  22. deathrowdave
    deathrowdave
    from NKy
    I hate to be stupid, but are 100% sure it’s a Dana 60 . I have seen a Dana 44 in early trucks , never seen a 60 , 5 lug in a Ford 1/2 Ton . That does not mean they were not there , but super rare . A real son of a gun to swap years in vs. the 9 in. Bottom casting near the cover will define if it is a 44 or 60 . It will be cast into the housing . Any housing 65 -79 will be a direct bolt in swap , in fact from 48 to 79 had very slight changes mostly shock mounts on the rear axle housing . Again if you need any help or small parts , my Buddy has owned 3 of them to date .
    CBurne7 likes this.
  23. CBurne7
    CBurne7
    Read um and weep. Lol.
    Unless it's been swapped out at some point, but I have no reason to believe this truck is anything but original.
  24. deathrowdave
    deathrowdave
    from NKy
    I have to agree , you are 100% correct . It’s rated at 3300 lb same as the 9 inch . I have to honest , I have snagged 100s in the junk yards through the years , not one have I ever seen with a Dana 60 . That’s a rare bird in deed . But again you are correct by the door code it is in deed a Dana 60
    CBurne7 likes this.
  25. CBurne7
    CBurne7
    I've got the truck back at my garage now. Working on getting the 352 fired up, but it's going to need brakes, tires, and the wiring gone through since I'm finding some loose ends.
    Poking around on classified I found a 66 Q-code Thunderbird with a 428 sitting in a field, so naturally I bought the motor out of it and today a buddy and I went and pulled it out. It's supposedly a 70,000 mi motor, but I severely doubt it. It turns over great though. I plan on taking it to someplace in the Fort hood area (Eaton Balancing?) to rebuild the short block and go over the heads so that I can assemble it.
    I'm torn between calling it Rocket Dog II after the F100 my dad had when I kid and The Rust Tractor since there's a weathered bumper sticker on the tailgate that reads "Rust Tractor" lololol
    IMG-3976.JPG IMG-3975.JPG IMG-3972.JPG IMG-3971.JPG IMG-3970.JPG IMG-3969.JPG IMG-3968.JPG
    warhorseracing likes this.
  26. Make sure you get a 428 flywheel as those are the only externally-balanced FEs....
    Good score on both the truck and the motor. Those are getting very hard to find around here....
    First year for the twin I beam, great front suspension for a truck; those will take a beating. One tip; unless you plan on high-speed off-road excursions, run as stiff a front shock as you can, that will reduce bump steer by a lot. The last one I had, I ran Gabriel 'Adjustable E' set on full stiff. High speed on logging roads broke shocks/lower mounts though... LOL
    The big Dana rear in the F100 is very rare. Had a co-worker who had one, he needed a replacement axle and it took forever to get one.
    CBurne7 likes this.
  27. bigdog
    bigdog
    Holy shit, I'd take the whole T-bird.
  28. Wanderlust
    Wanderlust
    Exactly what I was thinking, that’s a solid looking bird
    CBurne7 likes this.
  29. CBurne7
    CBurne7
    The floor pans are COMPLETELY gone. This thing was seriously rusted out. I didn't take pictures, but I could have rolled under the car and sat up in the middle of the vehicle. It's still for sale I believe if you want it. PM me and I can get you in contact with the owner.
    Noted. This was an automatic car, so there was no flywheel unfortunately. I'll have to do some more searching or buy a new one. I wasn't planning on picking up a motor so soon after getting the truck, but this came up and was a smoking good deal, so I moved on it. It'll be a while before I start tearing this 428 down. I did some research on the head casting and they're C6AE-R heads, which look like they're Cobra Jet-like ports with standard sized valves. Pretty happy about that.
