Here's your chance to own a ground pounding all FORD powered Hot Rod Truck. I've decided to let go of my 1965 Ford F-100. This is probably one of the nicest 65 ford trucks out there, and it runs very strong to back it up. This isn't your typical 65 Ford truck. This thing gets down the road and drives super nice. Its been driven from Ohio to Detroit several times, as well as Iowa. It has also made several trips to the hot rod reunion in Bowling Green Ky. This truck was built to be a street machine and be strong enough to drive anywhere. The truck has been done from front to back: for starters, it's packing a punch under the hood with a well built 302 Edelbrock intake and Howard's camshaft, that has a great lope to it. The engine is backed by a 3 speed manual trans and it still has the factory 9'' rear end. Not only does this truck drive flawlessly its has a highway gear in it to save on fuel. Truck has Flowmaster exhaust which sounds great. The truck was taken down to bare metal and painted professionally with Hot Rodz gun metal grey. Before the paint was done the hood had been sent out and was professionally louvered. After the paint was done, an artist came in and laid the scallops and pin striping which really sets the truck off. Once the paint was done the bed was done in Rhino Liner, which turned out great! The suspension was upgraded to get it lower, it was done by adding the dream beam set up in the front end. There are no hidden secrets, this is a very nice, well built truck. Feel free to call with any questions. 5135436656. Thanks, Ron I will also consider all trades as well thanks
