1964 ford unibody truck questions
Discussion in 'The Hokey Ass Message Board' started by zombiezach, Feb 14, 2008.
  1. zombiezach
    zombiezach
    Just wanted some feedback on this truck. owner says 64' ford unibody truck with a 6cyl engine. thinking of this as my first project. any suggestions...good/bad idea?
  2. RODDOORS
    RODDOORS
    from NC
    Two things to check on these trucks. Tailgate as these are difficult to find and are specific to unibody trucks, and they tend to rust in the rear cab wall at the bed since this is only one thickness of sheetmetal.
    Otherwise great truck!
    BIG REAR WINDOW????
  3. The Big M
    The Big M
    They do present some challenges, but all in all great trucks. I've got a '62.
    RODDOORS is right about the problem areas mentioned. The intersection between bed and cab can be troublesome, but not impossible to remedy. There's a reinforcing channel underneath that tends to rust out. Also, the lower bed wall, just behind the rear corner of the door, is a common spot for rust-through. Most of the floor panels are reproduced, as are tailgates, fenders, rad supports, etc.
    The owner has the year wrong though. Unibody is 61-63 only. :)
  4. UnIOnViLLEHauNT
    UnIOnViLLEHauNT
    That is rare, but the 60 unibody is rarer.
  5. UnIOnViLLEHauNT
    UnIOnViLLEHauNT
    Also, typical rust areas...step into bed, the front cab bodymount (both rust tho) and there is an area of the outside of the bed that goes, maybe mentioned above at the cab/bed joint, but most all Ive seen are rusted out there. Great trucks, I had one but sold it. Dont really miss it cuz the straight axle rode like, well, a truck, but Im also a huge pussy and like power steering and modern amenities.
  6. The Big M
    The Big M
    Yes, cab mounts are also an issue. And lower door pillars (where the lower door hinge mounts). Both are reproduced.
    Lower door pillar carnage:
    And some of the in-progress shots of the other areas that needed attention:
    I purchased floorpans, cab steps, lower door pillars, and cab mounts and had them installed by a pro.
  7. MUDFLAP
    MUDFLAP
    from wyoming
    I know Ford only made these from '61 to '63 and Ford never built vehicles after they said they did but, ----- the one I had was a numbers matching "64 with a matching title. It does rust badly behind the cab.
  8. Roorda
    Roorda
    from Pella IA.
    all the unibodys i have checked out had dents in the hood. in the body lines above the hinges and rust the front edge of the hood out i had a hard time finding a usable hood.
  9. Insane 1
    Insane 1
    from Ennis TX
    I bought a straight 6,3 on the floor 62 last year for $700.00. Rust in all the common areas, and dont care, not even going to fix them. Have $2000.00 in it total and drive it every day. The big thing is front suspension. Just depends on what you want out of it. But rust somewhere I promise. Also hood hinges seem to be a problem w/these trucks
    As for a 64 never heard of that!
    Mine
  10. MP&C
    MP&C
    Here's a pic of my old truck, sold it a few years ago to a buddy of mine. He's now talking about laying the windshield back about 2-3", which should lower the lid and slide it back. I keep telling him to move the back wall back as well, would make more room for buckets to recline just a little. The louvered hood was an attempt to fix an overheat issue with the 427, which was finally traced to the AC condensor, which has been relocated under the bed. He's since got another hood for it, which does have the typical rust starting up front, so we're talking about pancaking it while it's being worked on.
    Another problem area besides those mentioned is the front of the rear quarter where the side of the bed joins, it is another trouble spot for rust.
  11. I`ve got a `62 Unibody. The front cabs mounts are rusted, as is the tailgate. Both are easy fixes. I need to do a little patching in the floor as well. My hood hinges are locked up, won`t close. I found a pair on a donor truck that open / shut good.
    These trucks also rust out behind the headlights on the core support.
    I think the short bed unibodys are great looking trucks.
  12. LOWLIDX50
    LOWLIDX50
    <object width="425" height="355"><param name="movie" value="<A href="http://www.youtube.com/v/liVmtbsh0pU&rel=1"></param><param">http://www.youtube.com/v/liVmtbsh0pU&rel=1"></param><param name="wmode" value="transparent"></param><embed src="http://www.youtube.com/v/liVmtbsh0pU&rel=1" type="application/x-shockwave-flash" wmode="transparent" width="425" height="355"></embed></object>This is a solution to rust..Ibuilt this one a few years back . Lowlidx50
  13. LOWLIDX50
    LOWLIDX50
    I dont think my linky worked . search youtube for[lowlidx50]or [lincoln town truck] thanks Lowlidx50
  14. zombiezach
    zombiezach
    kool thanks for the feedback. im going to consider after seeing the amount of rust body work involved...its a 63' not 64 as well
  15. These lil trucks rock!
    Go to www.slicks60s.org for an awesome messageboard bout these trucks...
    -Shiny
  16. zombiezach
    zombiezach
    sweet site thanks
  17. fordified1
    fordified1
    I just bought a 61 and am excited to start on it. So far haven't found any rust-through. Looks like the tailgate has been patched though.
    Is there anything I can use to kill the surface rust's progression that won't change the color of it much? I like the way the body looks as-is.
  18. lefty11
    lefty11
    My Unibody has original paint... What do you mean by "rust"?? :eek:
  19. UnIOnViLLEHauNT
    UnIOnViLLEHauNT
  20. Mattilac
    Mattilac
    Hey fordified1, have those wheels on your 61 been reversed? Must be a bitch to steer if that's so...
  21. 64chrysler300
    64chrysler300
    It could probably just be that the owner messed up on the date of the truck cause they onle made em from '61-'63
  22. stuart in mn
    stuart in mn
    The VIN plates on 61-66 Ford trucks are on the driver's door, and as far as I know the doors interchange between all years. If someone in the past swapped the driver's door for a new one the truck may well have ended up being titled under the newer VIN.
  23. eddie1
    eddie1
    [​IMG][/quote]
    Please educate me, which ones have the larger back window like the one above?
  24. stuart in mn
    stuart in mn
    The big rear window was an uncommon option that I think was available on any F-series truck 1961-1966. I'm guessing that you had to also have the Custom Cab option as well (fancier trim, instrument panel, upholstery, etc.) to get the big window.
  25. Hey, Stu, nice to see you here on HAMB. You and I now have three forums in common!
    I think the big window was offered as a standalone option on Styleside (wide bed) trucks only. My '65 F100 isn't a Custom Cab, but it has the big window.
  26. Mattilac
    Mattilac
    Sorry Bill, but your '65 doesn't have the big back window. That's the stock window that 95% of these trucks all have.
  27. Yep, nope.
  28. My mistake! I forgot about the wraparound big back window. Y'all are correct; mine has the standard window.
  29. Dirk35
    Dirk35
    You, Sir (and your friend), should NOT pancake that hood!
    That'll be $0.02. K,Thx.
    If you wish me to elaborate on my unsolicited opinion, please let me know.
    Beautiful truck, by the way!
  30. stuart in mn
    stuart in mn
    I thought I had something that described what trucks got the big window option in my files (I own a '66 F-100) but all I can find at the moment is a small reference to it being an RPO option.
    You too! It seems like there's been a lot of migration back and forth between the HAMB and PY boards recently.
Links on The Garage Journal are affiliated by SOVRN.
