1964 Ford Falcon Futura. 347 ci dyno'd 460 hp. 347 stroker dart 2 aluminum heads. 10.4:1 compression. 2.02/1.60 stainless valves/ Roller rockers. 5.0 Roller block. Dougs headers ceramic coated tri Y with X pipe into flow masters Electric fuel pump system. 5 speed. A5 box from AstroPerformance. 480 Ft TQ rated Tilton hydrualic throwout and zero effort clutch MDL. 9 inch rear end. 3.55 trac lok 28 spline moly axles. Front disc brakes. rear drum CPP front suspension. Qa1 Coil over shocks. 1 in front sway bar/ 3/4 rear sway addco sway bars Cal tracs and KYB shocks. New recaro style buckets. Moto Lita steering wheel with Cobra hub, All components work. 17 x 8 Coys rims with Z-1 Dunlop tires. Please do not contact me if you have never owned a muscle car or a you do not have a garage to store this car in. If your local and your interested in the car please do not ask for ten million pictures. Schedule with me to see the car. Built to carve canyons. Very fast and very clean. this is a well built driver. SERIOUS inquires only. [email protected] 760-315-0542
