1964 Fairlane Thunderbolt tribute
Discussion in 'Cars For Sale' started by iamflashman, Jun 14, 2019.
  1. iamflashman
    iamflashman
    City: Austin
    State: TEXAS!
    Price: 30000
    1964 Ford Fairlane 2 door sedan
    [​IMG]1964 Fairlane 500 by James Fleischman, on Flickr
    [​IMG]1964 Fairlane by James Fleischman, on Flickr
    [​IMG]1964 Fairlane 500 interior by James Fleischman, on Flickr
    This car is not an actual Thunderbolt (see below), but it is a 2 door sedan and looks the part.
    This car was treated to a rotisserie restoration finished in 2018. The underside was stripped and painted along with the rest of the car in wimbledon white.
    Every nut and bolt was removed, cleaned, painted and reinstalled. The panels were meticulously fitted over and over before paint was applied to make sure the gaps were good. This was not an overnight restoration.
    This thing is fast. I do not have track slips to prove it, but I would imagine it is low 10 to mid 11 second car at slowest.
    Less than 500 miles on the restoration.
    Clear texas title in my name.
    - Wimbledon white PPG DBC with PPG clear.
    - Fairlane 500 trim polished and side trim freshly painted.
    - Crites tear drop fiberglass hood
    - Crites ram air kit (replaces inner headlights with ram air)
    - Crites fiberglass bumpers
    - Crites shock tower kit used but thicker metal used for additional strength.
    - Crites export brace
    - Crites lower crossmember
    - Rear wheel well clearanced for larger diameter tires
    - All original fomoco glass in great shape with exception of the windshield which is new.
    - All weather strips and rubber replaced
    - All suspension was redone and detailed.
    - Engine compartment sand blasted and painted semigloss black.
    - 4 wheel disk brakes - SN95 mustang disk brakes in the front, explorer disk brakes in the back
    - 427 Windsor engine with Trickflow high port heads, solid roller cam, edelbrock performer air gap intake, roller rockers, high capacity oil pan, headers, aluminum water pump, MSD 6AL digital, Ford duraspark distributor, alternator. The cam is quite large and delivers a solid lopey idle with a great power curve.
    - Holley 850 HP double pumper carb
    - Brand new Tremec TKO 500 transmission
    - Modern Driveline hydraulic clutch assembly
    - Centerforce clutch disk and pressure plate
    - Subframe connectors (not the cheap kit ones, made with heavier gauge metal for strength)
    - Ford 9 inch rearend with 31 spline detroit locker, 4.11 gears, and extreme duty forged axles
    - 3 inch exhaust with flowmasters. H-pipe with droppable front section (makes it easier to pull transmission or engine)
    - American Racing VN215 15x6 wheels in front, 15x8 wheels in back with bf goodrich radial TA tires.
    - Interior has been restored in Ivy gold cloth and Dark Bronzemist metal
    - New Steering wheel
    - Correct Dodge A-100 bucket seats
    - Rear seat is from SMS
    - New carpet, rubber, etc
    - NOS gauges and detailed instument cluster
    - Radio and header delete
    - Hurst shifter handle with 5 speed ball
    - New door panels
    - New headliner
    - New package tray
    - Floors painted and then lizard skinned and then painted over to match
    - Trunk repainted
    - Battery mounted in trunk with 0 gauge battery wire running to the front.
    - High torque starter
    - New fuel and brake lines from front to back.
    Jeff Engelman and agshelby like this.
  2. iamflashman
    iamflashman
  3. iamflashman
    iamflashman
