I'm in the process of building another Fresh built 401 Buick nailhead engine. Built by Martin's Rod and Custom. Motor was in a 1964 wildcat. Engine code is KT. I also have a 65 switch pitch automatic transmission that I can sell for an addition cost. Carburetor shown is the correct quadJet carb that needs to be rebuilt. I do recommend an edelbrock carb which I will supply. Distributor is freshly rebuilt as well with a pertronix electronic ignition conversion. Rebuilt water pump with 5 vane impeller. engine color is the correct Buick blue green which is hard to tell in photos. I do have brackets along with Buick riviera parts and nailhead parts call me if you are looking for anything. 512-734-0150 Brant Martin
