Technical 1961 Galaxie Heater Core?
Discussion in 'The Hokey Ass Message Board' started by tommyd, Apr 26, 2014.
  1. tommyd
    tommyd
    from South Indy
    Anyone know where I can get a new one? They don't seem readily available. Thanks Tommy.
  2. Gman0046
    Gman0046
    Tommy, call 1-877-542-8192 they will fix you up. There was someone on here with a 61 Ford looking for a heater core that I sent there. He was pretty satisfied.
    Gary
  3. PushnFords
    PushnFords
    I ran into the same problem on a '61 Electra. My local radiator shop could order a core that would work much like recoring a radiator. I ended up looking through the catalogs and found one about the same size with about the same nipples then modified the heater box to hold it and modified the firewall for the nipples to come out of. More work at first but now it uses a run of the mill heater core.
  4. tommyd
    tommyd
    from South Indy
    Thanks for the help guys. Pushnfords, That's a lot of nipples!
  5. PushnFords
    PushnFords
    I can't help it. I like nipples.
  6. tommyd
    tommyd
    from South Indy
    I do have a really good radiator shop here in Indy that I can check with also. Looking on Evil-bay I see a couple that are used and leaking for $200.00. Sheesh!
  7. Gman0046
    Gman0046
    Tommy, Before I'd go with completely redesigning the system, I'd go with a Vintage Air Gen lV Sure Fit Heat & Air Unit. When you deal with Nipples I've always found it to be way more expensive in the long run.
    What ever you do, don't buy anything Made In China by small children unless you want to do the same job over again real soon.
    Call that phone # I gave you.
    Gary
  8. TANNERGANG
    TANNERGANG
    from alabama
    I have a Brand New one I bought for my '64 Ford Galaxie....if it'll work, I'll take $50
  9. tommyd
    tommyd
    from South Indy
    Looks to be totally different but that's a good deal for sure.
