1961 Econoline with auto transmission problem
Discussion in 'The Hokey Ass Message Board' started by jandk, Feb 18, 2015.
  1. jandk
    jandk
    I have a 61 Econoline. The previous owner replaced the engine and transmission with donors from a 65 Mustang (str 6). The transmission is an automatic.
    When i stop and place the transmission in park, it easy moves out. Sometimes even when i shut the door. Is there a way to correct this?
  2. That is most likely just a matter of adjusting the linkage. The shifter is at it's stop before the transmission lever is fully engaged in park
  3. jandk
    jandk
    I will look at the adjustment this evening. Thanks for the advice
  4. econopoor
    econopoor
    from Jackson TN
    Vic in SoCal makes a cable conversion for Econolines that gives it a clean crisp shift and should help this issue.
    [email protected]
    Duane in Tennessee
  5. Johnboy34
    Johnboy34
    from Seattle,Wa
    Did they use the stock 3 speed shift rail for the automatic? No detents? I did that a long time ago, used a console shift arm on trans so park was down towards your knee. Remembering I used first-reverse shift rail up in the reverse gate, could pop shifter into neutral for anti theft. :cool: Never had a problem with it poping out though.
