1961 chevy c10 apache i have had for 7 years. i have turn it from farm truck to kustom. I have driven this truck everywhere from long beach to las vegas. She is not a show car yes she has a few clips in the paint. this a truck that you can drive anywhere. i was going for a 60s custom look. engine gm 350 crate motor 260hp 4 bolt main block (with about 10k on it) stock gm exhaust manifolds edelbrock rpm performer intake holley street street avenger 650 carb stock gm hei distributor gm 327 valve covers with moon breather bell style air cleaner weiand water pump aluminum 4 core radiator spal electric fan ( i live in phoenix in the mid of summer she never goes over 190) exhaust is newer with flowmaster 40s transmission stock gm 350 turbo with bm shift kit 2000 stall hughes converter rear end 1968 chevy 12 bolt truck rear end 6 lug 307 gear. ( cruze at 75mph at 2700 rpm) band new drive line paint custom paint like i said it does have a few chips it ( done about 5 years ago) the colors are 80s chrysler cream and black both oem colors easy to get any where. the wood bed needs to be re finish or new wood. side of the inside bed peeled away (its raptor coating easy do it your self stuff) i do have a tail gate and band new wheel wells both need to be painted. custom one off hand done pinstriping suspension ( everyone one that drives it says in rides and drives like a late model truck) lower 4 in the rear with new lowing springs form ccp 3in drop spindles with power disc brakes from ccp new ccp shock all around new ball joints new arm bushings new tie rods all new brake lines power steering new rear end bushings oem style wheels 6 lug with 50s desoto dish hub caps interior custom cream paint moon eyes accessory gauges vintage style tachometer moon gold steering wheel reupholstered seat with white vinyl newer black carpet the whole floor and fire wall has hush mat all new window seals front rear and sides all new door seals lokar tall shifter all rewired with hay wire kit ( the whole truck ) I currently have it on ebay. I wanted to try here to. Since i have been getting a lot of off the wall questions like how easy does the back window come out.
