Feels like dumb question but did the 60-62 c10s have an adjuster for the drum brakes? I'm redoing the rear on my 60. I've swapped to disc up front, have a spare 62 axle and none seem to have the adjuster bar. They do have an adjuster 'wheel' and slot, but none of the rest of the hardware. If not, any reason I can't add this with the kit from a 70's? Otherwise what's the protocol...manually adjust on occasion?
May just have manual adjusters only, not uncommon on older stuff. As far as I know, you should be able to put self adjusters on it. Sent from my Moto G Play using The H.A.M.B. mobile app
should be manual adjusting brakes. The teeth on the adjuster wheel will be large, and rounded. Not like the small, sharp teeth on the adjuster for self adjusting brakes. Chevy trucks had self adjusters by 1964 you don't need self adjusters on the back of an truck...do it manually when you notice the pedal goes down a little further than it used to
I know.... But really, the rear brake shoes get very little wear, I would not bother putting self adjusters on it.
I almost didn't put them on, but I had the kit in hand, so took the extra time and did so. Thank goodness for internet pictures to aid in placement of parts. It's been a while since I've done drums.
