Projects 1960 Chrysler New Yorker Rustoration
Discussion in 'The Hokey Ass Message Board' started by BrandonBerkosky01, May 5, 2017.
  1. I do enjoy making my own replacement panels, but man when you can buy something already made it makes life easy.
    Now I can start tying in the trunk floor to the rear trunk panel and quarters.
    HEMI32 likes this.
  2. enloe
    enloe
    from east , tn.
    wow is all I can say about this car
  3. Progress.
    HEMI32, low budget and Squablow like this.
  4. scotts52
    scotts52
    Looking good. Did you make the trunk pan or did you buy it?
    BrandonBerkosky01 likes this.
  5. Thanks. Yeah I bought it. (classicparts4u). Same for the "trunk drops" or whatever they're called.
    The pan I wish I made myself. But I'm not sending it back. The side trunk drops are close. They'll need some convincing.
  6. choptop40
    choptop40
    Wedge is the word....
  7. scotts52
    scotts52
    I've heard them called trunk drop offs or extensions. . Guess they go by different names in different parts of the country. Kinda like drywall, gypsum board, sheetrock. Hahaha
    I have a 60 pioneer that needs the pan and drop offs.
  8. mr.chevrolet
    mr.chevrolet
    you're a brave man, and you have awesum cardboard skills. I like those patterns you've made.
  9. low budget
    low budget
    from Central Ky
    I would have already had to cut that haggled edge off that trunk lip, back to that crease anyway, weather I was going to replace it or not.:D
  10. This one that tears my pants everytime I crawl into the trunk?
  11. They're on eBay. $91 a set.
  12. I was joking with my dad today.
    I said dad after all the work on the rear end of the Yorker we MAY have a car that someone would consider a start to a nice project.
    brEad and czuch like this.
  13. longram60
    longram60
    This perked my interest. Did you make a 3D drawing to get these printed?
  14. No. The guy scanned the original and then edited the drawing. He's an engineer so he's good with cad. The final product is nice he added the radius on the chrome part.
  15. So close an yet so far. I stripped all the paint of the rear and now you can really see how bad it is. I'm slowly straightening it out.
    A lot of shrinking and beating down high spots.
    Shot from inside my garage. You can see my buddies crew cab on the right. My 55 Buick on the left. The chrysler and the 63 merc with my rollback behind it.
    T-roaster and brEad like this.
  16. choptop40
    choptop40
    Wow..keep us in the loop..
  17. carryallman
    carryallman
    WOW this should be a must see & read for all hamb members !! also should be nominated for most dedicated something !! i got a 70 impala -my says to scrap !!! i now need to rebuild it !!! thanks guy !! im sure this article will push a lot of project ahead !! thanks again
  18. It's refreshing to see the dedication of HAMB members.
    Thank you for posting.
  19. You guys are too kind!! I say if the vehicle means enough to you it's never too far gone.
    safetythird likes this.
  20. Pulled the front end off and removed drivetrain.
    Started and finished patching up the inner fenders today. Then started the drivers side fender.
    I'm a novice tig welder.
    brEad, HEMI32 and Squablow like this.
  21. Here's some cool old pictures I found.
    In 2010 I bought a 72 dodge wrecker at an estate sale for $200. So we had this great idea to move the chrysler. So I stacked bricks between the axle and frame because the leafs were all broken then we drove it around the block.
    And here's a pic from 2001.
    Squablow likes this.
  22. First fender patch down. I'm loving the tig life.
    A buddy of mine sold me two 9-1/4 police rears from 78 dodge st. Regis's.
    One has a posi. The other had good backing plates. So I'll make one of 2.
    enloe likes this.
  23. Still plugging away at the fender. Every time I use the tig my welds improve. I'm grinding less tungsten for sure. My beads are also getting cleaner and more uniform.
    HEMI32 likes this.
  24. What are you guys doing for layered panels such as this as far as coating? Does that weldable primer actually work? Maybe when it's done I can just soak it with some thinned down paint to really get in between?
    I hate to do all this for nothing.
    Thanks.
  25. Squablow
    Squablow
    I've heard good things about the weld through primer but don't discount good old fashioned seam sealer and undercoating. You want to keep dirt and moisture out of there in whatever way you can. Getting a coating on the surfaces helps, but so does closing up the seams and gaps.
    Nice work so far, you're really doing this car justice.
    brEad and BrandonBerkosky01 like this.
  26. When I took my tig class the instructor said there's 3 things that make a good welder. Practice, practice, practice
    Sent from my SM-G900V using The H.A.M.B. mobile app
  27. enloe
    enloe
    from east , tn.
    By the time you get done with this car you won't be a novice anymore you will be a master :)
  28. Themoose was nice enough to help me with a paint job on the car over in the photoshop thread. It's a satin blue.
    safetythird, T-roaster, brEad and 8 others like this.
  29. gatz
    gatz
    You're sure doing a great job, Brandon
    what did you buy for a TIG welder?
    is that yellow unit the one?
  30. Thank you. That's the Esab rebel emp215ci unfortunately I cannot tig weld aluminum. But if I was to upgrade to the 235 it would've been another thousand dollars. I just don't think I needed it that bad. I'm sure I'll be kicking myself in the ass over it though.
