1959 Chevy Apache Truck 3100 Half ton, short step side bed with full fenders (no spare tire cut outs) small rear window. Truck is very solid. All rust has been replaced with new sheet metal. Camaro Z28 sub frame with all new suspension, brakes, with heavy duty sway bar, and more. Extra bracing was used to tie in the sub frame to the original rails. Rear rails were c-notched and boxed for the Camaro 10 bolt rear end. Rebuilt SBC 400 with 882 heads, Lunati cam, Edelbrock Performer RPM, new headers, Holley 600 carb, new HEI distributor, TH350 trans with mild torque converter (around 2800 rpm). New aluminum radiator, power steering parts, and more. Weld Rodlite wheels with radial tires. Rear tires are as wide as you can go without tubbing the bed. Orginal bench seat that has been repaired and upholstered in black and white. Have door panel inserts that match. New chrome, tilt steering column and new GM style wheel. New in box tachometer and auxiliary gauges. Aftermarket brake pedal and master cylinder bracket, with new Napa dual reservoir master cylinder. New behind the seat gas tank, sending unit and filler hose. New in box rear roll pan. Many more parts. This is not a driving vehicle at the moment. It is not wired, engine has not been fired and the brakes are not plumbed. You will need a trailer to get the thing home. Title is clean. This would make a great project that most all the hard work is done. The truck is solid and has a terrific stance without being too low or having to use air suspension. I will not "barter" on price over text or the phone. I will not consider an offer until you look at the truck. For more details or to set up a time to see the truck you can call/text 918 - eightfive7 twenty5ten *** For some reason the pictures are not showing up. If you are interested in seeing some you can check my CL ad for them. Sorry for the inconvenience. https://tulsa.craigslist.org/cto/d/claremore-1959-chevy-apache-truck/6960933002.html Keywords / 58 59 1958 street rat muscle hot rod drag custom car cruise traditional
