Auctions
1959 292 engine
Discussion in 'Parts For Sale' started by streetdreams, Mar 30, 2015.
  1. City: Howell
    State: Michigan
    Price: $1400 OBO
    1959 292 core
    Engine is complete, disassembled, checked and a good, rebuildable core.
    Standard bore/ crank
    113 big intake cylinder heads ( ECZ-G's with larger combustion chambers )
    1.43 rockers
    flat top EDB exhaust manifolds
    manual bellhousing
    flywheel, pressure plate core
    2 barrel intake ( Autolite 2100 )
    FORD script valve covers
    This motor was pulled in the late '60s. Never reworked. Has original Ford bearings and hd gaskets.
    Have a ECZ-B 4 bbl intake for $150 extra with motor.
    No guessing or gambling on a core motor with this one. If you're thinking of updating your Y Block, this is a good starting point. My shop can also rebuild to your specs, and yes, I can do the oiling system mods, rework the rockers to full pressure lube and install cam bearings correctly.
