Projects 1958 Ford 2 door Ranch wagon rear side window ??
Discussion in 'The Hokey Ass Message Board' started by 55olds88, Apr 30, 2018.
  1. 55olds88
    55olds88
    Hi all,
    I have a 58 Ranch wagon, its missing the side glass and frame on one side (L/H)and I'm looking to get a replacement , does anyone know if the frame is the same on the 57 or other years ?
  2. BJR
    BJR
    57 is the same basic body, so I would think it should fit.
  3. southcross2631
    southcross2631
    If you can't find the glass, you can form sheetmetal and make it a sedan delivery. That way you can get it on the road. Then you can tell people that it is a even more rare version of the Ranch Wagon.
  4. Johnboy34
    Johnboy34
    from Seattle,Wa
    Have you called some of those big antique junk yards in Idaho and Arizona?
    Sent from my SM-G900V using The H.A.M.B. mobile app
  5. '57/58 are identical, so either year will work. The side glass is all flat laminated, you can have that cut to size. You'll also need the latches for the slider (IIRC, '55/56 will also work), the channels for the slider, the U-shaped seal for the stationary windows, and the seal between the two pieces. I believe the channels and stationary seal are being reproduced.
  6. TKEBH964
    TKEBH964
    from MO
    Dennis Carpenter or MACs will have all of the rubber you need. As stated earlier, 57/58 side glass is the same.
  7. 55olds88
    55olds88
    thanks for the info guys, will see if I can find a complete unit somewhere otherwise there are some good leads.
