Technical 1958 Cruise-o-matic problems
Discussion in 'The Hokey Ass Message Board' started by Wiley1905, Jun 24, 2016.
  1. Wiley1905
    Wiley1905
    I recently purchased a 1958 Ford thunderbird. Well, almost 2 years ago. Ive been working on it all the time that I might get between work & family. I bit off a little more than I can chew, but I'm definitely catching up now... I &ave a 352 FE with a Cruise-o-matic. I only have reverse, no drives.., any suggestions?
  2. squirrel
    Did the car ever move under it's own power in recent history, or is it likely that the bad transmission is the reason it was parked?
  3. Wiley1905
    Wiley1905
    When I bought it I started it off of the solenoid & it lurched foward a bit. But I have taken the engine out since then, without the trans
    Sent from my SPH-L710 using H.A.M.B. mobile app
  4. Wiley1905
    Wiley1905
    When I bought the car I started it from the solenoid & it lurched foward a bit. So I assumed that the trans was decent, I pulled the engine out, To rebuild it, slapped it back in, thinking I was goo to go. But when I wires it up & fired it up only went into reverse. Tried leaving it in the drive gears for a couple minutes, but to no avail
  5. squirrel
    You did make sure the fluid level is correct? And the shift linkage is adjusted properly?
  6. czuch
    czuch
    from vail az
    We bought a 63 Dodge 300 that had sat for a few years.
    Finally after getting it started, it needed about 15 minutes in drive, idling to "remember" what it was supposed to do.
    Good times.
    Wiley1905 likes this.
  7. d2_willys
    d2_willys
    from Kansas
    Forward clutch is not applying. Sounds like valve body or the forward clutch piston seal is dried up.
  8. Atwater Mike
    Atwater Mike
    Hey, D2! Isn't there an 1/8th pipe threaded plug up forward on a Cruiso than can be removed and a pressure gauge applied for a test on that port?
    Many years ago, slight memory jog.....
  9. Wiley1905
    Wiley1905
    Yes
  10. Wiley1905
    Wiley1905
    I've been talking to alot of different people that have alot of different opinions on the matter, but everything keeps leaning towards the valve body.. thanks man
  11. They're pretty simple and something is either gummed up or dried out. Get a general rebuild kit and dive into it, take lots of pictures!
  12. d2_willys
    d2_willys
    from Kansas
    If there is (and I don't recall), then I would start there. Plug gauge in, raise rear end of car so wheels are off ground, then run car in drive right, observe pressure. If no pressure clean valve body and possibly governor. If pressure (even if on low side), then forward clutch is the problem and a complete teardown of transmission. Another approach is to remove valve body and find forward clutch passage. Then apply compressed air and listen for a thud. Thud will be there if forward clutch piston and the clutch plates are reasonably good.
  13. carguy699
    carguy699
    the old car project has an online 58 ford shop manual with a complete cruise o matic section. it helped me a lot when I got my 58 fairlane which had forward gears but not reverse. turned out to be dried up seals in mine which required a rebuild.. fyi rebuild kits are available but hard parts can be pricey!
    jim
  14. 57Custom300
    57Custom300
    from Arizona
    As mentioned, my guess is a dried up forward clutch seal. As far as air checking it, make sure your only using about 15psi to apply the clutch. Any clutch will sound like it applied with 120psi to it. And I would be surprised if it turned out to be the valve body, but stranger things have happened.
  15. sunbeam
    sunbeam
    There is a pipe plug for a pressure gauge just forward of the shift lever pressure should read 56-68 psi @ idle in all gears.
  16. d2_willys
    d2_willys
    from Kansas
    15psi may be on the low side. If being applied by 50-60psi I would use minimum of 40psi air.
