1958 Chevy pickup frame swap
Discussion in 'The Hokey Ass Message Board' started by hellboy333, Sep 24, 2012.
  1. hellboy333
    hellboy333
    from Amarillo
    I have a 1958 Chevy short wide and was wondering if a 1957 Chevy panel wagon is the frame.
  2. squirrel
    I guess that depends what you mean by "panel wagon". There is no such thing, but there is a panel truck:
    and a sedan delivery
    The 57 panel truck has the same frame as the short bed 57 pickup, but it does have two frame extensions riveted to the back of the frame, and a sway bar mount at the front. And the 58 truck frame is a couple inches longer at the front than the 57 frame. So you can cut down a 58 frame to fit a 57, or weld on a bit to a 57 frame to make it fit a 58
  3. hellboy333
    hellboy333
    from Amarillo
    right on man thanks
  4. mphudak
    mphudak
    from Atlanta
    Seems i read somewhere that the radiator mounts are different from 55-57 and 58-59's w/the sheet metal change over.
  5. APACHE FS
    APACHE FS
    ^^^Core support is but frame is same ^^
  6. squirrel
    The core support mounts on the frame are a bit different too.
  7. APACHE FS
    APACHE FS
    What's the mount look like on the 5-7? I know the 8,9 just has a small bracket riveted on the frame ( I guess to raise it) should be easy to fab though if he has a donor frame.
  8. squirrel
    The 55-57 has a small mount riveted to the frame also, there are two different versions for 6 or 8 cylinder (the radiator was in a different place). Neither one is the same as the 58-59 bracket.
  9. APACHE FS
    APACHE FS
    Ok, I was wondering if there was a 6vs8 difference thanks
