Does anyone make a radiator for a 57 pontiac? How about some dimensions and I can maybe get a universal one to fit.
I don't know, but chevy/pontiac shared a lot. You might check under the hood of the next chevy you see. The difference maybe inlet/outlet locations. If I recall chevy was center upper, RH (pass.side) lower. V8 was behind support, L6 was in front. Someone on here should know. Posted using the Full Custom H.A.M.B. App!
I used a company called champion on fleece BAY , it was Alum and 190 + 30 SHIPPING , they had listings for many models of cars for comparison from Spdway was $750
i'd be scared as hell of a $190 aluminum rad. I'd be willing to bet theres epoxy used in the assembly process which leads to premature failure at best. Clogged and damage causing at worse. We are a PRC dealer and only use their radiators at the shop. furnace brazed, FULLY tig welded, nice units. If they've never made one for your particular app we have a custom build form that they will build a one off for you. Just had that done for a local guy for a 70s triumph. Prices start around $450 on their units. The only other ones i've seen that i think compare are from Wizard Cooling...ken....
