1957 Chevy Step Van build or do you want to see my Gerstenslager
Discussion in 'The Antiquated' started by anthony myrick, Aug 7, 2018.
  1. anthony myrick
    anthony myrick
    from al
    Found this in our local scrap yard
    4201BC1B-03FE-416E-9F60-301087130903.jpeg 65B50C56-A365-4E32-A8CB-5E1A60D3B0DE.jpeg
    brEad, 302GMC, OahuEli and 1 other person like this.
  2. anthony myrick
    anthony myrick
    from al
    turns out its a former mail truck the body is made by Gerstenslager
    has a government delivery plate from early 1957
    think I may just pull the trigger
    slv63 likes this.
  3. anthony myrick
    anthony myrick
    from al
    we got it in the shop
    students cleaned it out and are removing the chassis
    plans are to lower it and refinish it to resemble its former mail truck glory
    it has a 235 but is missing the hydromatic. I still have the hydro adapter, starter and flexplate if someone needs them
    I have a 472 Caddy that may end up powering this
  4. BamaMav
    BamaMav
    from Berry, AL
    Cool truck!
    anthony myrick likes this.
  5. theburningbush
    theburningbush
    from Tacoma WA
  6. anthony myrick
    anthony myrick
    from al
    I teach at a high school tech center
    I do old stuff like this mixed in with the newer stuff. Great for recruiting
  7. BamaMav
    BamaMav
    from Berry, AL
    I'm guessing that it's 3/4 or 1 ton suspension?
  8. anthony myrick
    anthony myrick
    from al
    3/4. It only has a 6700 gvw
    Going more than likely with 1/2 ton stuff
    Has a cool dropped factory axle that would drop a normal truck of the same years a bunch
    I need about an 8 inch drop and using the stock stuff want do that
    brEad and lothiandon1940 like this.
  9. anthony myrick
    anthony myrick
    from al
    we got the frame out
  10. anthony myrick
    anthony myrick
    from al
  11. anthony myrick
    anthony myrick
    from al
    I think we want to run these or something close
    the Buick bezels would fit how the body is stamped in the headlight area
    some Kaiser Manhattan ones would look great if I could find some without another mortgage
    OahuEli and lothiandon1940 like this.
  12. anthony myrick
    anthony myrick
    from al
  13. anthony myrick
    anthony myrick
    from al
    Students pulled the engine out yesterday. Might save this exhaust manifold Looks like it would make a cool split exhaust.
    brEad, OahuEli and chevy57dude like this.
  14. chevy57dude
    chevy57dude
    As a lover of all '57 Chevys, let me say that one's ugly! But I like it.
    Great that you are getting young people involved with some old tin.
    Guess you have to tolerate their wheel choices..
    Will there be plans for paint? My thought was to see if a local blasting company would donate time/material? Patina is free, of course..
    lothiandon1940 likes this.
  15. anthony myrick
    anthony myrick
    from al
    Plans are to build the chassis and drive as is while we “restore” the original mail truck look
  16. anthony myrick
    anthony myrick
    from al
    Got to make an engine choice soon. We have the 472 on our run stand. Seems to have a mechanical timing issue. If we have to build an engine we may just use a 283 power pack I have. I do have a good running 235 but would include adding a clutch mechanism to the van. (It used to have a hydro)
    I also thought about a 250 6cl.
    We marked the front and rear axle center lines on the chassis today and removed the original suspension. Students will check the frame for squareness and start figuring out final ride heights and begin chassis mods
  17. anthony myrick
    anthony myrick
    from al
    Students have almost stripped the frame
    they are now removing all unnecessary brackets..........drill, hammer, repeat
    They have located front and rear axle center lines and are checking it for squarness
    we are now measuring ride height and verifying the wheelbase, we need to move the front wheels forward slightly to center them in the wheel openings.
    Students are also planning the new front x-member....measure cut, weld
    we are going to make it a bolt in to improve the ability to remove the engine without removing the body.
    we got a huge mess to clean up tomorrow.
    I use opportunities like this to teach chassis measurement and repair, suspension components and alignment
  18. anthony myrick
    anthony myrick
    from al
    our 472 is showing very low compression, just a little over 30 psi but on all 8
    PO said the car was running fine then shut down on him and never got it to run correctly again
    we did discover that PO had the firing order backwards and had severely damaged the distributor. looks like he threw a lot of new parts on it trying to diagnose the bad running condition.
    he also complained about it flooding, wonder if this has something to do with the low compression numbers
    car had around 80k miles on it.
  19. Great project!......I asked a young lady once if she wanted to see my Gerstenslager and she smacked me!:eek::D
  20. chevy57dude
    chevy57dude
    Don, that's one you "pop out" once you are acquainted!
    The students of this truck are fortunate to have such a teacher.
    Teaching is a calling in life, few are in it for the money. The experience from this class will remain with them long after the book work fades.
  21. anthony myrick
    anthony myrick
    from al
    We built this 2 years ago
    brEad, Okie Pete, VANDENPLAS and 3 others like this.
  22. ....So true........I was married to a teacher. I understand and respect their dedication to their craft.
    chevy57dude and anthony myrick like this.
  23. anthony myrick
    anthony myrick
    from al
    Students did good this week
    all suspension and mounting brackets, unnecessary x-members were removed
    they know how to remove rivets now
    brEad likes this.
  24. chevy57dude
    chevy57dude
    Searching ''Gerstenlager'' brought up a lot of bookmobile images.
    This one looked cool.
  25. anthony myrick
    anthony myrick
    from al
    They also built the Weiner mobile
    lothiandon1940 and chevy57dude like this.
  26. anthony myrick
    anthony myrick
    from al
    Students noticed something weird about the paint on one side. Hmmmmmm
    This is untouched as found
  27. woodbutcher
    woodbutcher
    :D Just amazing what can be revealed by some removal of old paint.
    Good luck.Have fun.Be safe.
    Leo
  28. One of it's ghosts from it's past.
  29. anthony myrick
    anthony myrick
    from al
    Not removed
    This is how it was found.
    This is when we first got it in the shop. Zoom in on the rear portion of the bus and watch it apear
