I'm looking for a video on replacing my '57 rear passenger side window regulator. Seems I can find everything but the 2 door hardtop.
Purchase an assembly manual for a 1957; they are reprints available from almost any Tri-Five vendor. I am Butch/56sedandelivery.
I bought my oem service manual on amazon for cheap, Heres a link to the tri five forum, , they have lottsa reference material . https://www.trifive.com/threads/window-regulator-replacement.102065/.Danchuck has diy videos .
If you plan to take the glass all the way out. There is a guide in the rear that can come loose first. Loose not out. Then loosen the regulator. Work the glass Chanel loose from the regulator. Then wedge the glass gently in the opening. Remove the regulator
