Projects 1956 Plymouth Savoy 270 poly Running! !
Discussion in 'Traditional Customs' started by 50's Firm, Aug 4, 2014.
  1. 50's Firm
    50's Firm
    Just wanted to share the badassedness of her running. 12"glasspacks sound so pretty. 270 polyspherical head .030 over, hot grind cam, Manton pushrods, hardened seats, decked.
  2. swifty
    swifty
    Those early polys are great looking engines and that one should move that Plymouth along nicely.
  3. sunbeam
    sunbeam
    Great looking engine but I really would think about a 318 balancer.
  4. saltflats
    saltflats
    from Missouri
    Nice looking engine man.
    sunbeam whats the 318 balancer do for it tuck the pulleys in closer?
  5. George
    George
    A lot of the low deck Dodges came w/o a damper.
  6. sunbeam
    sunbeam
    Low deck dodge car motors came without dampers and some had crank problems. Just good insurance.
  7. 73RR
    73RR
    ...plenty of cracked cranks in the 241-260-270 w/o the harmonic dampener.
    A and LA dampeners fit with a stepped key or you can re-broach the hub. Yes, the timing marks will be useless but easy to remark for TDC.
    Frankie47 likes this.
  8. George
    George
    Intended to say... A lot of the low deck Dodges came w/o a damper. Adding one cuts down on crank problems, guess I was in a hurry!:(
  9. saltflats
    saltflats
    from Missouri
    Kool thanks guys I learned something today now I can start drinking.
  10. yes....nice car and motor.....
  11. 50's Firm
    50's Firm
    Thanks y'all. I did read that crank breakage was an issue sometimes. I'll look into the dampener.
  12. George
    George
    Primarily a problem racing 241s, but it would be a good idea to put one on.
  13. SteppinOut
    SteppinOut
    Great looking ride. Nothing like the sound of the first run either. Congrats, bet it sounds great.
  14. porky55
    porky55
    Nice. How'd you lower it? Cut coils.
