1956 chevy gasser build
Discussion in 'The Hokey Ass Message Board' started by Uncledirty616, Apr 28, 2012.
  1. Uncledirty616
    Uncledirty616
    yep , gonna make it a tilt, i kinda have become attached to the frankenstein look the car has. @ hudsoncustom.....Keith?
  2. Uncledirty616
    Uncledirty616
    getting ready for ladder bars...and yes i know ladder bars and leaf springs bind, gonna try an experiment, if it doesnt work i will be putting coil overs under it. [​IMG]
  3. Uncledirty616
    Uncledirty616
    looks pretty cool, even if the engineering might be a little dated =)
  4. Uncledirty616
    Uncledirty616
    final welding on the ladder bar brackets then off to be assembled, and monday the frame goes to the blaster!!!
  5. 55chieftain
    55chieftain
    Nice progress. Why not just use some housing floaters and set it up right. I would do that before coilovers.
  6. 1971BB427
    1971BB427
    from Oregon
    Looks like you're moving along at a good pace!
  7. Uncledirty616
    Uncledirty616
    I heard they tear up the rear end housing pretty bad, and i guess i just dont like the way they look. I know that isnt the most sound reason. Plus the guy helping me had an idea we want to try. secret squirrel double top security plans muhahahahahaaaa
  8. Uncledirty616
    Uncledirty616
    So, not much to update today, but i did this little assortment of goodies in the mail today. Now if you know me, i am NOT a chrome person, but i couldnt resist this for some reason, to me , its right for the look im going for , for the car.
  9. Uncledirty616
    Uncledirty616
    Well, the frame goes off tomorrow to be blasted, and i am gonna pull the front clip apart so we can set it up to become a one piece, and .......I go get the engine, or at least part of it!!!! Still makin pretty good progress.
  10. Uncledirty616
    Uncledirty616
    picked up the motor this morning!! Assemble, then off to be dynoed!!
  11. el Scotto
    el Scotto
    from Tracy, CA
  12. biscaynes
    biscaynes
    sweet! more please! :cool:
  13. Uncledirty616
    Uncledirty616
    picking up the freshly sand blasted frame
  14. Uncledirty616
    Uncledirty616
    new floor bolted down
  15. Uncledirty616
    Uncledirty616
    preparing to remove the old rusted out floor
  16. Uncledirty616
    Uncledirty616
    rust be gone....more to come
  17. nice work Joel! fuckin get it! Are you gonna assemble that engine yourself then?
  18. ModelAPunk
    ModelAPunk
    from Buffalo NY
    I'm a sucker for a tri 5 gasser build! Keep it up, can't wait to see the final product! Good Luck with the build!
  19. Uncledirty616
    Uncledirty616
    Thank you ModelAPunk, and yeah Keith, gonna put that sucker together as soon as my pistons come in. This was supposed to be my budget motor, just to get the car going.
    Discovered almost no one makes good pistons for the old closed chamber heads anymore. So....i had to get some really good high dollar JEs =/ I guess its not a bad thing but more then i wanted to spend on pistons for this motor. Cool part is they are almost a hundred grams lighter then the cast hypereutectics i originally purchased for the build (back when it was gonna have oval port heads and a very mild cam)
  20. Uncledirty616
    Uncledirty616
    turning down the wheel spacers
  21. Uncledirty616
    Uncledirty616
    the slicks are now under the car
  22. Uncledirty616
    Uncledirty616
    I mean Literally, under the car!!
  23. Uncledirty616
    Uncledirty616
    "Adjusting" the new floor for tire clearance
  24. Uncledirty616
    Uncledirty616
    our stopping point for the night, one side now has clearance, just needs to be cleaned up , then do the same to the other side
  25. Uncledirty616
    Uncledirty616
    oooh look its a box of goodys =)
  26. Uncledirty616
    Uncledirty616
    now that is one fine lookin piston!
  27. Hale to the dome ! What compression is this going to work out to be ?
  28. Uncledirty616
    Uncledirty616
    I have 107 cc cumbustion chambers, so 12.5, i have a weird custom ground cam, so im interested to see where this all works on the dyno
  29. Uncledirty616
    Uncledirty616
    Got the body back over the floors, and getting ready to weld.
