This unit was used for a racing setup using two Single Quad Carter WCFB Carburetors that flowed more cfm than the smaller Corvette DQ WCFB carbs. It fits a 265, 283, 302, 327, 350 & 400 ci engine. The front carb has the correct top without the choke setup 6-1299 and Bowl 0-1953. The rear carb top is 6-1271 and Bowl 0-1518. A NOS AC Filter as well as the steel gas lines and fittings are included. Carbs will need a rebuild kit. Good for a performance motor or a starter setup for an Original DQ Setup. Call Tom at 1 609 397-0161 or [email protected]
