Projects 1955 Pontiac Catalina Gasser 427 BBC 8-71 Blown - MONTANA CAR
Discussion in 'The Hokey Ass Message Board' started by 427heaven, Sep 27, 2019.
  1. 427heaven
    427heaven
    Bought this car from Montana in 2008. Owner on Reg is "Ron Dare" deceased. Seized 389 engine, but has chromed solid axle. 1964 5.38 diff.
    Just finished roll bar. New 427 BBC with 8-71 blower, T-400. Fired up on Sept 5th, 2019
    Drag srip first pass on new drivetrain Sept 6th, 2019.
    Does anyone recognize this car from Idaho or Montana? 20190906_180302_Moment (2).jpg
    Deuces, 67drake, j-jock and 10 others like this.
  2. 427heaven
    427heaven
    55 cat.jpg 2008 When trailered from Dillon, Montana
    Deuces, catdad49 and kidcampbell71 like this.
  3. 427heaven
    427heaven
    FIRST PASS with blown 427 BBC
    Deuces, 67drake, j-jock and 6 others like this.
  4. 427heaven
    427heaven
    First fire 427 Sept 5, 2019
  5. catdad49
    catdad49
    1st pass on My birthday, you know I Like it! Share more when you get time.
  6. wvenfield
    wvenfield
    Yeah, I'd like to see more info and pics.
  7. 427heaven
    427heaven
  8. 427heaven
    427heaven
  9. 427heaven
    427heaven
    Chrome dropped front axle done in 60's or 70's maybe. With econoline style hubs and drums
  10. 427heaven
    427heaven
  11. 427heaven
    427heaven
    Solid Roller cam .700 lift, 2 x 1050 Holleys, Iron heads. 8-71 BDS blower driven at 19 over, 14 lbs boost
    Deuces, j-jock, loudbang and 2 others like this.
  12. That is hairy!
    What was your ET, RT and mph?
    Deuces and loudbang like this.
  13. 427heaven
    427heaven
    Partial pass only. Shakedown pass. 95 mph half track. Probably a 11.00.
    Should do much better next year.
    This was end of season Friday night drags here in the north.
    Hoping for low 10's at 130's
    Worked like a dog to get out once this year.
    Didn't blow up.
    Didn't hit the wall.
    All good.
    Fired it up Sept 5th.
    Went to track Sept 6th.
  14. 427heaven
    427heaven
    Home built engine with:
    GM truck block - used - bored and torque plate honed
    Iron square port open chamber heads - rebuilt
    Steel crank - used GM - polished
    TRW dished forged pistons 7.5 compression - slightly used - balanced assembly
    Comp Solid Roller Cam - custom - comp lifters
    New BDS 8-71 Blower 19% overdriven - off Ebay
    2 - new 1050 Holley Dominator Carbs - off Ebay - boost referenced at home
  15. 427heaven
    427heaven
  16. 427heaven
    427heaven
  17. 427heaven
    427heaven
  18. 427heaven
    427heaven
    Dyno sheets from 2012 on this engine.
    Deuces and kidcampbell71 like this.
  19. turbo69bird
    turbo69bird
    from CT
    Don’t know how old this thread is but I’d put the Pontiac back in my 69 bird ran 11s stock in 1969 My turbo charged Pontiac 455 runs 9s all day long off the foot brake with a lazy 60ft. Not to mention in those days guys were tanking chebbys out of vetted and dropping in Pontiacs. So period correct would likely be a Pontiac.
    These days it’s as cheap or cheaper to build Pontiac too with all the stroker kits etc and is bet it get a ton more attention being poncho powered. There’s a sea of Chevy stuff and people get bored with it. It’ll also increase its value nothing sells worse than a poncho w a Chevy in it.
    awesome car awesome motor just probably not as cool together as the real deal poncho stuff in that car.
    Just my .02
    as long as you love it that’s what matters but a lot of people overlook Pontiacs. But before the Chevy aftermarket took over Pontiacs were whooping Chevy.
    RmK57, loudbang and Todd553 like this.
  20. 67SPCL
    67SPCL
    Greetings!
    I owned that car in the early 90s when I
    lived in Missoula, and in fact sold it to Ron Dare.
    It came from Utah.
    I got it from my step dad who'd gotten it from his brother.
    I was in my early 20s at the time and clueless about what to do with it.
    It ran when I sold it, but barely.
    I remember the starter was somehow switched from the column shifter,
    so you had to turn the key on, then start it by pushing the shifter all the way up.
    It's on top of the list of cars I wish I'd never sold.
    Glad to see someone is loving her!!!
    loudbang and 67drake like this.
  21. Brian Hedberg
    Brian Hedberg
    Thanks a lot for the info.
    Just what I was hoping for.
    The Montana Title says Ron Dare registered it in January 23rd, 1995.
    He, or someone had started to take the car apart.
    It was dry stored in a barn, pretty complete.
    The front straight axle looks pretty old.
    I don't suppose you know who put that front frame stub on with the Chromed drop axle??
    And... was it actually raced at a track?
    It has a later Olds/Pontiac 1964 5.38 Positrac diff. with aftermarket axles!
    Pretty stiff gears for a street car.
    And it had a roll-bar at one time for sure as there were holes and under-floor plates from that.
    Love to hear more history.
  22. 67SPCL
    67SPCL
    I have no idea who built that car.
    I'm pretty sure it was drag-raced out at Bonneville Raceway
    (not Bonneville Speedway) at some point in the '80s
    I remember my stepdad telling me it had a what he called a
    "drop out" rear end and it seemed like a big deal to him.
    I later learned it was actually called a third member
    when I was replacing one on a '65 Chevy 3/4 ton.
    I didn't know the one on the Pontiac was posi,
    and back then I didn't even know what that meant.
    I don't know any more history on that car,
    but more important than where it's been is where it's going,
    and you seem to have given her new life, which is what she deserved.
