I need to rebuild my Powerflite transmission mounted behind my 291, but am also thinking about swapping it out. The key items that I want to maintain are the dash shift lever (unique and sweet) and transmission mounted emergency brake. Anyone out there done a swap?
If you look for a mid 60's to late 70's motor homes with a 318/440 the trans - they will have the drum brake on the rear. The shift linage on the motor homes has a dash shifter with a cable to the trans. If you can find a Winnebago in a wrecking yard - you could check it out. There are parts available to adapt the later trans to your engine as well.
@1955Desoto Considering your goals (retaining dash shifter and parking brake) IMO your simplest and likely least expensive option is to overhaul your Powerflite. Ray
I had a '54 DeSoto with Powerflite that needed "rebuilding." It wouldn't shift out of low below 45 and was spitting fluid out the dipstick tube. Transmission shop sent me to a retired transmission man who had worked on many of them over the years. He told me, based upon the symptoms I described, that it was the governor. Swapped one out of another Powerflite and back on the road. Not saying that is your problem but that's what mine turned out to be.
