Projects 1955 Chevy Southeast Gassers Build
Discussion in 'Traditional Hot Rods' started by Zak Hall, Oct 29, 2017.
  1. greaser
    greaser
    Are you going to add X bracing side to side on the roll bar?
  2. Zak Hall
    Zak Hall
    No we’re not gonna X the door bars. Makes it hard to get in and out lol.
    Floater03, loudbang and Bowtie Coupe like this.
  3. greaser
    greaser
    Sorry, I meant side to side, (Behind driver).
    Bowtie Coupe and loudbang like this.
  4. Zak Hall
    Zak Hall
    You mean x-ing the down bars coming off the main hoop like that?
    Butch M, loudbang and Bowtie Coupe like this.
  5. greaser
    greaser
    Yes sir! I believe X bracing in that direction would make a significant difference.
  6. Mike Colemire
    Mike Colemire
    Glad to see pics of it right side up, don't want it to get used to being upside down, LOL.
    brEad, Dog_Patch, loudbang and 2 others like this.
  7. Zak Hall
    Zak Hall
    We’re not gonna do that, it’s extra weight and we’re trying to keep it as light as possible. Plus it takes away from the nostalgic look. The halo bar and down bars on the 10 point cage is bad enough.
  8. Zak Hall
    Zak Hall
    232AD93A-9337-41FE-AC38-1DAABB26674B.jpeg DFD42706-433B-4345-B8C8-DA3F87E5FFEC.jpeg B9594E20-EC0F-4A84-8979-AEE66652514F.jpeg 9DD33287-636A-4E4D-B9A8-A2027AE329A2.jpeg 857328C1-31CC-4B01-B0DB-3BCFB0BC8CA1.jpeg 9B8E3196-278D-446E-B652-7A944425E69B.jpeg
    Got the frame done and everything painted, got the seats bolted in to see how they looked, and got the axle bolted in for the final time. Got the steering box on too. Gotta go to the bolt store in the morning to get bolts to finish the steering up, and we’ll have the front end done tomorrow. Starting to put stuff on for the final time. It’s getting exciting.
  9. rawcjw19
    rawcjw19
    Looks great. Dumb question for you. Does the bar along the rocker need to be there? I wasn’t sure if we need 1 or what the reason was for it
  10. Mike Colemire
    Mike Colemire
    Yes, it has to be there.
  11. greybeard360
    greybeard360
    Answer is... If the rocker panels or floors are not factory, those bars have to be there.
    Sent from my Moto G Play using The H.A.M.B. mobile app
    Bowtie Coupe, rawcjw19 and loudbang like this.
  12. Zak Hall
    Zak Hall
    Actually Tri fives dont require a rocker bar per nhra rules because the frame is wide enough. But it’s chromoly so it weighs only a couple pounds, adds rigitity in the frame, and makes a good place to mount the body to.
  13. Zak Hall
    Zak Hall
    A6096D6B-F9B9-4B1C-B798-C80EADD14379.jpeg 9C747276-D452-4EA2-86C9-A2C0DC6C020C.jpeg 30748003-0AE2-4D29-A421-DEC6C615EA89.jpeg F17C2BAF-A031-4688-8A09-4D62015CF5D2.jpeg FE306016-71D9-4EC7-B8FC-B221768E2A5D.jpeg Steering is done, and it’s back up rolling. Gotta mount the rear springs and the track locator, and the suspension will be done. Gonna mount the body this week and start mounting fiberglass. Hopefully it’ll be in color in a few weeks.
  14. blownhemi48
    blownhemi48
    from Bergen NY
  15. Zak Hall
    Zak Hall
    They’re empi seats I got them from speedway, and yes I got the black vinyl covers. They’re better than the rci lowbacks like I put in my 57 and the covers are nicer too.
  16. Zak Hall
    Zak Hall
    8FAFB97C-A6E3-4B7C-910C-956D722F7280.jpeg Got the spring buckets jack screws and all that for the rear suspension. Gonna have to notch the frame to get the coil directly under the frame rail between the fram and the axle housing.
    catdad49, loudbang, Dog_Patch and 2 others like this.
  17. blownhemi48
    blownhemi48
    from Bergen NY
    Good deal. They look like the only ones wide enough for my fat ass.
  18. Bajita
    Bajita
    from Laredo
    Awesome 55 chevy gasser.
    Competition orange paint would make it look mean with the injectors and the five spoke wheels. Keep them photos coming. Great job.
    loudbang and Zak Hall like this.
  19. Zak Hall
    Zak Hall
    I’m not small lol. These fit pretty good and are fairly comfortable. My hip bones are too wide for those tiny fiberglass seats.
  20. southcross2631
    southcross2631
    I used the EMPI seats in my Morris Minor. The sit pretty good . Comfortable enough for some 1/8 th mile trips.
  21. blownhemi48
    blownhemi48
    from Bergen NY
    Very nice. Thanks for the replies.
  22. Zak Hall
    Zak Hall
    78538D18-AA26-4D5E-A498-057A835F01AA.jpeg 251BCEB7-E186-47FA-B781-85961C1A548F.jpeg B370A225-CE6E-4877-825B-5C7C827C097A.jpeg 9043194B-7B79-41CD-86FE-6781AB898CB7.jpeg Got the frame notched, got some pieces broke and welded in to box it, got the screw jacks and coil spring mounts in. Track locator bar is next and we’re done with the suspension.
    Butch M, Dog_Patch, loudbang and 4 others like this.
  23. Zak Hall
    Zak Hall
    DEBEF4E9-B522-4B4B-B439-06A328573BA5.jpeg AE127A41-40B8-4A85-B77E-7FCDD4A87FDF.jpeg 912A5828-67D5-4B0D-86A4-F35C807B7154.jpeg
    Track locator is in. We had to make a stand so it could be level and long as possible. Trying to keep it light, but want to make sure it handles well too.
    Butch M, catdad49, Dog_Patch and 6 others like this.
  24. Andy
    Andy
    It will handle better if the track locator is mounted as low as possible. Look how the 60's GM cars mounted them. Look how low the NASCAR cars have them.
    I also would like to see your rear radius rods without the crook in the top bar. The vertical load will try to bend them and it could steer the car. The right side will bend first.
    Bowtie Coupe likes this.
  25. Zak Hall
    Zak Hall
    As per Southeast gasser rules, the track locator has to come off the top of the rear end, for a 60s look. I would have ran the track locator diagonally across the bottom from the front of the ladder bar to the rear end if it was allowed, like modern cars are built. But it’s against the rules. And what are you talking about, the top bar on the ladder bars?
  26. Zak Hall
    Zak Hall
    37BA9DF6-7B3A-4882-BB75-F560168DDB0B.jpeg 0CD92459-0861-456C-9150-8CAB3C75034B.jpeg 0CD12CFF-4933-4C3C-9E47-1555AF928E27.jpeg The ladder bars are competition engineering ladder link bars. If they didn’t have the straight away at the back, you couldn’t adjust them because the to connecting points would grow in distance from each other and you couldn’t get the bolts back into the mounting brackets on the rear end. I’ve got the same ladder bars on my 57 and it works well. And here’s a picture of an anglia Quain and Donovan Stott built for a guy, same basic design we used on the 55 here.
    Butch M, jim snow, catdad49 and 6 others like this.
  27. Zak Hall
    Zak Hall
    59724F85-F1D1-4C14-B190-37C9007161E4.jpeg DE5B641E-7302-45D6-BBE2-B2562C188044.jpeg E00F82EE-33F1-49D8-A2FC-1AEE2650D5D5.jpeg C6395F48-5D7B-45A1-AB9D-1E34214B47F4.jpeg 87736EE1-E28F-4768-A6AD-DCF65C71BC07.jpeg Starting to look like a car again.
    brEad, FlatJan, Woogeroo and 10 others like this.
  28. Zak Hall
    Zak Hall
    69BA359C-9ED3-4BB8-B3A9-180D9830B5D8.jpeg A97ACF4B-CE5D-421C-9B26-0A82589AE4D1.jpeg C2004E72-FE78-4B6E-9DE3-07CC0EED8512.jpeg E84F4BB8-F244-4EA1-A70C-F3093E17FD73.jpeg EEA6751F-E09B-41C3-A030-578658D18466.jpeg DA9CF3FE-7924-4C33-B91C-858ED8355539.jpeg AC999443-1319-4F86-AB8F-5DD2F084BE3C.jpeg 8B41406B-375B-416B-B31D-8DE1F3D73405.jpeg Body is mounted! Next up is the gas tank, radiator, wheel tubs, and quarter patches.
    Butch M, rawcjw19, loudbang and 5 others like this.
  29. southcross2631
    southcross2631
    Looks like a real car. I would done the body repairs with the body off . Just me, everybody does it different. Nice job so far.
    Zak Hall and Bowtie Coupe like this.
  30. catdad49
    catdad49
    I see a little weight saving provided by Mother Nature ( or the metal mice)! How do you find time to post all this?! Thanks, Carp
    Zak Hall, Bowtie Coupe and loudbang like this.
