1955 Chevy real sedan delivery! Straight body looks good, ! doors shut solid rear hatch shuts solid!...everything fits good for a car at this price point! White epoxy primer. Lettering and stripes slightly aged by hand. New floor pans New peep mirrors WAS TOLD engine is a '68 big journal 327 with double hump heads and big valves but we have not personally run casting numbers. Chrome valve covers, Edelbrock carb with electric choke, HEI, standard ram horn exhaust manifolds. engine bangs right off ,holds 40-50 lbs. of oil pressure hot or cold and runs between 180-190 degrees F. ALL the time. Good acceleration and sounds stout........no smoke or blowby or any other monkey biz. New motor and tranny mounts 400 Turbo tranny had it gone through by my tranny guy prior to installation. Everything in good order and new filter and fluid. We put on a fancy flex fill steel braided filler neck. stock converter . New Mr Gasket shifter (steel rod not cable) Stock rear end All new stock brakes.....master cylinder, wheels cylinders and shoes, some short lines, and hoses (emergency brake not hooked up but have new cable for it) New aluminum radiator New exhaust and pipes (dump under in front of rear end in case you want to lower it with blocks) old skool glass paks. New windshield, gasket , new door glass and felt channels regulators all greased up. New rear hatch glass gasket. wing window glass and rubber seals were not replaced. New wiring front to back done the old school way .......stock fuse box and spools of wire, crimp connectors and black tape. New tail light bezels and lenses New rear bumper New underdash gauges all working (oil pressure, volt, temperature) All running lights work, aftermarket turn signals work and stop lights work , orig gauge cluster lights work New fuel tank and sender unit and filler neck. Gas gauge works. Four brand new tires on vintage Ansen/Fenton style slots will polish up nicely. New battery New idler arm upgrade with the ball bearings (poor mans power steering) Call for more details . 817-9two9-4nine2five No trades! $13,500
Polished up the ol slots a little bit. Threw a blanket over that seat. Looks a whole lot better now. I'll throw up some pics later.
