I need a replacement spring for the stock Pcv valve or a replacement unit, 261 c.i. I checked all the usual sources and haven't had any luck. Help guys
^^^^^^^^ Quite a few larger vehicles have been equipped with PCV valves since the '30s. Only, instead of PCV, they're known as Donaldson valves ….
There were kits made to install them back then usually from California,I have found they were installed in WWII trucks that were driven through water.
