Customs 1955 Cadillac hydra-matic what fluid??
Discussion in 'The Hokey Ass Message Board' started by The G00SE, Mar 20, 2015.
  1. The G00SE
    The G00SE
    Ok folks I have a 55 Cadillac 331 hydra-matic combo im stuffing in a 56 Cadillac coupe. It's time to start filling up fluids. The fluid that came out of the tranny was clean but didn't look like dex/merc . Ive been having trouble scaring up info on what people are using. I posted on the hamb Cadillac cruiser page and one Cadillac brethren posted back that he is using b&m trick shift ( thank you). I saw one other post on the internet were a guy said dex/merc is fine to use . Can anyone confirm that? I dont know squat about trannies, thanks for any help.
  2. I've used Dexron in mine but have Type F in it at present... supposedly shifts better and leaks less.
  3. chopolds
    chopolds
    from howell, nj
    1. Kustom Painters
    Used whatever version of Dexron that was available during the entire time I drove my 55 Olds, with hydro. Still works fine, since 1982.
  4. The G00SE
    The G00SE
    Alright guys thanks for the help. With that type F do you notice a difference? Warbird1
  5. d2_willys
    d2_willys
    from Kansas
    I use Dexron III in my hydros. (All single coupling types like you have). The type F fluid has more abrasives in it and some of the friction components might wear a little faster than with Dexron III.
  6. The G00SE
    The G00SE
    Alright d2willys thanks for the heads up . Ill go with the dex 111. Keep it simple. Thanks again every one
  7. I ran type F in my 4sp. hydramatic after an overhaul. Operated perfectly.
  8. Nope, never noticed any difference with the Type F in my single-range clunker. I'll probably go back to Dexron when I install the rebuilt Olds dual-range in my roadster.
  9. pontiac
    pontiac
    I run Dexron III/DexMerc in my dual range Hydra-matic... 11 years, 80k+ miles no issues.
  10. Fender1325
    Fender1325
    I have a 1950 hydramatic (1950 cadillac 331) and I use Dexron VI. I mustve called 6 cadillac dealers to see if they could verify an article I read claiming theres a service bulletin stating all modern dexron's are compatible with all previous generation dexrons. Not surprisingly none could answer, but I got a hold of an older hyrdramatic rebuilder/specialist who told me the VI would be fine. So far everything seems just fine.
    I do believe I read the VI has a stronger shear capability designed for the tighter tolerance modern gm transmissions. I think it might be more like comparing synthetic to standard. Seemed to leak a little at first but that went away. The car has been parked for many years and is just waking back up. Good luck. I think you'll be fine with III or VI.
  11. Using Dexron III in my Jetaway, after a fresh rebuild.
    Bishop Schulz likes this.
  12. The G00SE
    The G00SE
    Thanks every body
  13. Hogbud
    Hogbud
    Great conversation, just getting ready to purchase my 12 quarts for my 55 Hydraglide 4 speed.
    Love to be part of this crowd on Jalopyjournal, always good stuff.
    HB
