Technical 1955 buick century 2dr. hardtop vin location.
Discussion in 'The Hokey Ass Message Board' started by 55 dude, Aug 27, 2017.
  1. guys, i need some help locating vin numbers for a 1955 buick that is missing the vin tag off the left body cowl in front of left door.it really makes it a pain when these tags are missing, was hoping buick stamped it somewhere on the frame like other makes of vehicles i have owned in the past, thanks!:)
  2. choptop40
    choptop40
    Usually somewhere near the steering box if I remember
  3. anyone else?
  4. Msgr. Doug Cook
    Msgr. Doug Cook
    The number may be taken off the engine, stamped onto the block on a tab , left side of the engine, between the two center exhaust manifold ports. Number should end in a 6 for the Century series
  5. mgtstumpy
    mgtstumpy
    https://www.teambuick.com/reference/years/55.php
    NAILHEAD Codes 'til '58
    The engine serial number is stamped on a machined surface on the top outer edge of the left cylinder bank, between the middle branches of the exhaust manifold. The last digit of the engine serial number is 4 for Series 40, 5 for Series 50, 6 for Series 60, 7 for Series 70. According to some sources, a 100 suffix is used for the Series 100 Skylark of 1954.
    A stamped 1/4" long dash after the production code number indicates a .010" O.S. production engine. It is not unusual to find the letter I used in place of the number 1 in the id numbers (this makes alteration more difficult). In some cases the letter I is intended, as in the case of year identifier character for 62. The VIN is the same as the engine serial number for 1957 to 64.
    http://www.buickheritagealliance.org/index.php/restoration/identify/locate_numbers
  6. gggholson
    gggholson
    I have found them stamped as far forward as the frame horn on the drivers side. Usually requires fender removal when they are that far forward.
  7. BJR
    BJR
    Look on the top of the rear frame behind the axle crossmember. That's where I found the number on my 49 Buick frame. Passenger side.
