Pair of '55-'59 Chevy truck front shock mount brackets. The bolt-on studs are dead, but the brackets themselves are solid. If you own one of these trucks, you know these mounts are always busted and welded. I started to grind the rivets, but cutting them out of the frame was easier, so I'll let you cut the rivets out. $75 plus the ride in a flat rate box. I'll have removed the shock studs by the time you read this to make them fit in a flat box.
