Technical 1954 Packard what'sit ?
Discussion in 'The Hokey Ass Message Board' started by gatz, Feb 18, 2020.
  1. gatz
    gatz
    Was looking at a '54 Packard for sale and saw this.....
    It says "clutch", but what does it do?
  2. studebakerjoe
    studebakerjoe
    I don't know if Packard still had it in 1954 but at one time they had something I think they called electromatic clutch that was one of those automated clutches like Hudson had. The button is probably so you could disengage it and drive it like a regular manual.
  3. If you buy it and if it's a '54 Caribbean with the big straight 8 and if you're not going to use it. PM me please.
  4. 03GMCSonoma
    03GMCSonoma
    Are you sure it isn't a 1950 Packard? I did some Googling a '54 dash doesn't look like this. The switches looked like our '50 Packard so I did some more Googling. We had a three in a tree with overdrive so we didn't have this switch/button. Looks like a '50. Here is the Wikepedia page that explains it. https://en.wikipedia.org/wiki/Ultramatic
    I ass-u-me the electromatic and the ultramatic are the same. but...…… Hope this helps.
  5. egads
    egads
    From the net ( not me )????????----------;Mid-1930s to mid-50s cars have always been my favorite cars. Being born in 1949, I have memories of seeing those cars on the road being driven daily. It wasnt until around 1960 when the pre-war cars were more seldom seen.
    Along with the styling evolution from mid-30s Art Deco, streamlining, envelope bodies and the chrome rolling juke box styles of the 50s, there were a lot of mechanical innovations that were introduced, and some worked really well, making for much less labor-intensive driving. I just covered a two-part series on Packards R-9 overdrive. It worked well for years, evolving into the R-11, staying popular even after the Ultramatic (automatic) was introduced in 1949. During this period, many car manufacturers were ultimately working toward an all-automatic transmission. The goal was to make their cars easier to drive and entice women to be potential car buyers.
    So many of the car makers offered overdrives, and semi-automatics (vacuum clutches, etc.). Oldsmobile was the first one to bring out a reliable fully automatic transmission in 1938 with GMs Hydramatic. Packard added to the ease of driving with its Electromatic clutch introduced in 1941 and continued through 1949. It was evidenced by a red clutch pedal until mid-48, then black through 1949. Here is how Packard described the vacuum-electric Electromatic clutch function:
    The Electromatic clutch which is supplied as special equipment automatically accomplishes the engagement and disengagement of the clutch. The car is started, gears shifted and the accelerator pedal used in the usual way, but without touching the clutch pedal. Even when stopping, it is not necessary to touch the clutch pedal.
    To lock out the Electromatic clutch and restore the normal use of the clutch pedal, pull out the switch knob on the instrument panel marked Electromatic. When it is desired to return to electromatic operation, push in the switch knob.
    The Electromatic clutch with overdrive consists of:
    1. The Lockout Switch, located in the instrument panel, which enables the driver to select the Electromatic Clutch or lock it out at will.
    2. The Lockout Solenoid Valve located in the clutch control valve, which is energized and de-energized manually by the lockout switch and automatically by other switches. It locks in and locks out the Electromatic Clutch when desired by the driver, or automatically when driving conditions require it.
    *Packard Owners Manual, 1946-47
    3. The Clutch Control Valve, which regulates the partial vacuum by metering the amount of air admitted to the power cylinder and supplies the varying pressures for smooth clutch engagement.
    4. The Power Cylinder. This device provides the force required for the degree of engagement and disengagement of the clutch as directed by the clutch control valve. The power cylinder diaphragm is connected to the clutch relay lever by means of a cable-pulley system.
    5. The Governor Switch, which prevents disengagement of the clutch when the accelerator is released at speeds greater than governed speed.*
    6. The Direct Speed Switch, which is operated by the direct and second idler lever and permits shifting from high gear above governed speeds. The direct and second idler lever mechanically closes the direct speed switch at the first movement of the shifting lever out of high gear and insures that the direct speed switch is open only when the car is in direct drive and overdrive.
    7. The Accelerator Switch, which locks in the Electromatic, releasing the clutch only when the accelerator pedal is fully released below governed speed.
  6. v8flat44
    v8flat44
    Gatz, the dash you show is 48-50. My dad had a 48 & a 50. Both had e clutch & overdrive & were good runners. He later had a 51 & 53 Patricians with auto trans. I think the e clutch was gone in 1951 and never did a Carribean have a six. 1956 was the last Carribean & dad had one. 372 cubes with dual quads......THAT CAR WAS...............F A S T !
    kidcampbell71 likes this.
  7. gatz
    gatz
    My mistake....
    It IS from a 1950 Packard Standard 8
    Sorry about that.
