Installing 1954 F-100 parking light assembly wiring from bulb does it go down thru gravel pan or up thru grill into headlight bucket area------ Thanks
The little hole in the Gravel Pan is a drain hole for water, not for the park/turn wire. You should have a terminal block for all forward wires towards the front of the Left side inner fender panel. The Park/Turn wire follows your Headlight Wires and drops down inside the Grill behind the headlight bucket into the Park light housing per each side. The Wizzard
