Technical 1954 Dodge C1 tranny shift pattern figured out
Discussion in 'The Hokey Ass Message Board' started by Dan Yager, Jun 1, 2023.
  1. Dan Yager
    Dan Yager
    After much time and grinding gears I figured out the 5 speed shift pattern!! And it sucks! Ha ha I need more on the top end! Ha!
  2. J. A. Miller
    J. A. Miller
    from Central NY
    Probably don't need to use 1st unless you're loaded down.
    rusty valley and Dan Yager like this.
  3. Dan Yager
    Dan Yager
    Heck I don’t even use second gear right now! Ha ha crazy stuff. Must have really needed the low gears for heavy loads
  4. rusty valley
    rusty valley
    Is it synchronized ? Try shifting at lower RPM's than your ears tell you to, old motors and old trannys like low rpms.
    Dan Yager likes this.
  5. gene-koning
    gene-koning
    Old trucks were work trucks. They were used for many kinds of work. Its entirely possible that 1st was because a very slow truck speed was required for some reason. Might not have anything to do with grear reduction for pulling a load.
  6. Dan Yager
    Dan Yager
    I’ll give it a try
  7. Dan Yager
    Dan Yager
    Allegedly it is a synchro-mesh tranny
