1954 Chevy ignition switch????
Discussion in 'The Hokey Ass Message Board' started by sickiee32, Jan 2, 2014.
  1. sickiee32
    sickiee32
    OK WOKE UP THIS MORNING TO FIND OUT KNOW ONE HAS A BRAND NEW IGNITION SWITCH FOR MY BROKEN ONE IN MY 1954 CHEVY 210!!!:confused::confused::confused:
    ANYONE KNOW WHERE TO GET ONE????:eek:
  2. squirrel
    several on ebay, GM part number 1116478 but they're not cheap, and they don't include the lock cylinder.
  3. Mike51Merc
    Mike51Merc
    It's probably because you didn't use enough caps or punctuation.
  4. sickiee32
    sickiee32
    Is that part number for a OEM one?
  5. squirrel
    yeah that's the GM part number.
  6. sickiee32
    sickiee32
    Next question.....if the switch turns without a key in it and starts....is that the ignition switch or the ignition lock cylinder?????
  7. Is the ignition in the lock position or the off position? If its turning while in the lock position the lock cylinder is probably the cause.
  8. sickiee32
    sickiee32
    its turning in the lock position and allowing the car to start with or without the key in it
  9. squirrel
    You can take out the lock cylinder, to look at it...maybe post pictures if you can't figure out what's wrong.
    See the little hole in the lock cylinder? Turn the key to lock position, poke the end of a paper clip in the hole to gently push the spring loaded lock pin, then turn the key to the left a little bit, and the lock cylinder should then pull out.
    Look for wear, both on the lock cylinder and in the switch. It's all made of pot metal, not very strong stuff.
  10. chigger
    chigger
    National Chevy association or chevs of the 40's
  11. sickiee32
    sickiee32
    they do not carry correct ignition switches .... but it might be lock , gonna pull it and lookie
  12. 49ratfink
    49ratfink
    I don't know if they were different in 54, but in 49 there was locked to one side, and unlocked to the other, so if you took your car to a mechanic you could leave the ignition off to the unlock side and the mechanic could start it without a key.
    is there still a push button to start the car in 54?
  13. sickiee32
    sickiee32
    little bar that springs ride in was broken.... $11 fix lol
  14. Use a 55 chevy it comes out of a 12 volt system and are cheaper easier to find,
  15. rember if you got high amp stuff hooked to switch use relays they make 70 amp relays and this old crap wont last very good with high loads
  16. sickiee32
    sickiee32
    Yeah its just for now!!! otherwise anyone could hop in and steal my scoot
  17. squirrel
    looks like the bar popped out where it was staked in at the end. I've seen that happen before...it's a rather flaky design that they used for decades
  18. sickiee32
    sickiee32
    yep...just ordered a new one via truckandcarshop.com
  19. sickiee32
    sickiee32
    you were right !!! just the lock broke
