Technical 1954 Chevy Bumper and Door Gap Help
Discussion in 'Traditional Customs' started by Dead End Sleds, Apr 23, 2019.
  1. Dead End Sleds
    Dead End Sleds
    I apologize for rambling here. But, I need information please. I'll give a little info how I got into the situation, bc some typically want to know that.
    Long story short (as possible): Took my car to body shop of guy I know. Does good work, but is slow. So, I thought I knew what I was getting into. Paid money up front hoping it would motivate him to get it done.
    He had guy who knew and liked old cars working for him at the time. Old guy tore apart and got some stuff done. Old guy takes off, never to be heard from again.
    After a couple years, we're at a point to paint. New guy is having issues with door gaps and the ends of the front bumper. He didn't take it apart. So is starting fresh. So, I'm wondering what is normal for door gaps. Also, are there typically any rubber bushings or something to protect front of fender from bumper?
    I'm not sure I'm posting enough or correct information here for my questions to be answered. So if anything else necessary, let me know. Thank you. IMG_20190422_150626.jpeg IMG_20190422_150621.jpeg IMG_20190422_150515.jpeg IMG_20190422_150510.jpeg IMG_20190422_150537.jpeg IMG_20190422_150457.jpeg
    Sent from my Nexus 6P using The H.A.M.B. mobile app
  2. what was wrong with the car when they started? was it dented, crashed or rotted?
  3. 2 years = body shop prison. I like to see a uniform 3/16" gap all around. The front fender should be able to be jockeyed to help that. I like to leave everything snug, but it should still be able to be moved. I like to match-drill doors to the hinges before I take it apart, but only after my gaps are perfect. I like to keep bumper to body gaps uniform side to side. I don't know of any bumpers for the front of Chevy doors, but tape the edges in case they rub while you are doing the final adjustments.
  4. Dead End Sleds
    Dead End Sleds
    Nothing. Just having it redone. I have photos of it before body shop in my profile. I think it's the Current Status album Bumper wasn't straight at that time.
  5. Dead End Sleds
    Dead End Sleds
    Thank you bobss396.
  6. BJR
    BJR
    Both doors look low, as the body lines do not line up, and looks tight at the rocker. Also look like they could move forward a little to open up the gaps at the quarter. If the bumper was sent to be straightened it may not have been shaped perfectly. I would fix all of the stuff before you paint.
  7. Terrible80
    Terrible80
    Not to be a prick, but money up front sometimes removes the incentive for prompt , quality work.
    Sent from my LG-TP450 using The H.A.M.B. mobile app
    Frankie47 likes this.
  8. Dead End Sleds
    Dead End Sleds
    I learned that the hard way. Now I'm just trying to get out the situation I got into.
    Terrible80 likes this.
  9. the reason I asked was if they did a lot of welding/replacing panels they may have welded them in crooked. if it was aligned when it went in, and they did not cut and reshape anything, it should be able to be adjusted. it almost looks like the cowl [just the cowl] is rocked to one side. are the body mounts all in good shape, or new? and the nose looks like it is over to one side. start with good body mounts, then align the doors to the quarter panel, then fit the fenders to the doors, adjust the hood to the cowl, then adjust the front of the fenders to the hood/frame/bumper.
  10. BJR
    BJR
    How can you possibly tell if the nose is off to one side by the pictures the OP posted?
  11. little red 50
    little red 50
    In the pictures last 2 pictures posted those are the grill ends not the bumper. More than likely after market pieces that do not fit properly. I went through that on my 54.
    56premiere likes this.
  12. Dead End Sleds
    Dead End Sleds
    You are correct. The originals were buggered up bad and too frustrated to get the correct names of parts.
    little red 50 likes this.
  13. Dead End Sleds
    Dead End Sleds
    Thanks for this. I'll forward this on to them. There was no cutting except to put the '55 eyebrows on. I don't know about the body mounts. Unfortunately, that's why I took it to someplace that is supposed to know this.
    tb33anda3rd likes this.
  14. alchemy
    alchemy
    Step one: align the doors. They hang too low in the back and will probably sag a little more with all the window weight in them. I think having them a 1/32 high to begin with sounds good.
    Then the bodyman can start worrying about the gap. Might need to add metal to the door, or grind and weld if it's too tight.
    As for the grille parts, I think you have found the issue with repro vs. original. Looks like it will be easier for the bodyman to bend the fender than bend the stainless grille. That shouldn't be hard for a good bodyman though. A bit of hammer hammer, then some grind grind, more hammer hammer, then filler and sand sand.
