1954 Chevy Belair 235 Oil Change
Discussion in 'The Hokey Ass Message Board' started by 54LedSled, Nov 16, 2012.
  1. 54LedSled
    54LedSled
    Just to make things clear, I have 54 235 with PG and Factory Oil Canister. How many quarts does it take to do an change with the filter? My last 235 didn't have an oil filteration system.
    Thanks. :)
  2. vinnymac44
    vinnymac44
    from W. Oregon
    My "56" 235 with a beehive filter takes 5 quarts.
  3. engine138
    engine138
    from Commack NY
  4. 54LedSled
    54LedSled
    I know this sounds a little stupid but how to you drain the oil in the canister now? at the hose? How much of the 5 qts do put in the canister with the new filter in?
  5. 54LedSled
    54LedSled
  6. Ole don
    Ole don
    The correct routing for the oil filter is, the hose comes out the bottom and goes to the bottom of the block. It all runs downhill. It drains itself when the motor is not running.
  7. GREASER815
    GREASER815
    Yep, self draining filter, 5qts. oil, easy as can be.
  8. Wipe the canister out also
  9. 54LedSled
    54LedSled
    Thanks guys, finally when adding new oil do I need put any in the canister? If so, how much?
  10. vinnymac44
    vinnymac44
    from W. Oregon
    Nope. Just put it in the engine, it will make it to the filter.
  11. 54LedSled
    54LedSled
    Again, thanks guys!
  12. Interesting , my 54 filter tank does not self drain,does that mean something is wrong with mine?
  13. GREASER815
    GREASER815
    Check and see if your return line is plugged
  14. JohnEvans
    JohnEvans
    from Phoenix AZ
    Well being I drove a 54 -235 for more years than I care to remember I can tell you with filter it takes 6 quarts. System without filter is 5 qts, add right at 1qt for the filter. Pour 5 qts in the engine after draining the old ,wait a few minutes and then read your dipstick. Unless the stick has been screwed with it should read full.
    Normal A-C filter housings have the oil return hole high on the center tube so housing has oil in it when you pull the cover. My second purchase after a grease gun was a oil suction gun to empty the damm thing.
  15. 54LedSled
    54LedSled
    So John are you saying I should pour the last (6th quart) directly into the filter canister or the motor with the other 5 quarts?
  16. JohnEvans
    JohnEvans
    from Phoenix AZ
    Just pour it into the engine as that qt will get into the filter in a couple of minutes.
  17. Convert54
    Convert54
    from Oklahoma
    just remove the old filter, siphon the remaining oil out with a pump, install the new filter, add a quart of oil, put the top back on before you start it(dont ask how I know that one) and other than filling the crank your set.
    Some of the add on filter canisters did not have pet cocks on them.
    sroysr likes this.
  18. jcmarz
    jcmarz
    from Chino, Ca
    I happen to have a Fram canister off my 216 and it has a drain plug. By the way, I am not using it and if anyone is interested in buying it for 40 plus shipment, PM me
