Awesome 1954 Chevy pickup AD half ton. These are the ones everyone wants. One piece windshield..cool paint. Solid truck! Picked this up after about a year of searching. Owner before me is a custom metal fabricator at a well known shop in Minnesota. Truck is on original frame but has been modernized with a mid 80's xjs/sje Jaguar front end. Done right and overkill with the support/welding. The previous owner did himself and this is what he does for a living so was done properly in a shop. Rear is from a s10 blazer 4x4 with 3.73 gears posi. uses stock rotors with Speedway calipers that have the e-brake built in. The ebrake is not there.. Tires only have a couple hundred miles on them. exhaust is ram horn manifolds in to 2" pipes with thrush glass packs and full tail pipes. so its the best of both, it idles pretty quiet and isn't too loud when your cruising, but it will rap when you get on it. Motor is a sweet 305 bolted to a 5 speed t5 Borg Warner transmission. Shifts great! Was in a 58 wagon and runs awesome. Exhaust is nice sounding cherry bombs...not too loud or soft. To show how detailed this build was, I have a list of all parts for motor, trans, etc with part numbers from Oreilleys. Never had that before! Located in Nashville TN area Clean title in hand.
