City: Caddo State: Oklahoma Price: $15,500 USD City: Caddo State: Oklahoma City: Caddo State: Oklahoma Price: $13,500 USD Up on the block today is my 53 2 door vicky. Rebuilt 289 with mild cam, 3x2 Rochester carbs on blue thunder intake with progressive linkage. Mallory distributor, polished Cal Custom valve covers mated to a Tremec T5 Transmission with hydraulic clutch set up, balanced aluminum drive shaft. Chassis-Fat man Fabricators front stub with stainless steel A arms, dropped spindles, manual steering rack and sway bar. New shocks on all four corners, new de-arched Jamco springs with blocks at rear. Dual master cylinder, front disc brakes, rear drums on a Granada Rear End, all new brake lines. Wheels blasted, primed and painted with Firestone 6.70x15 Whitewalls. New fuel tank with new fuel line, pump, filter and regulator. Conversion to 12v with Rebel wiring harness. Body off the frame for floor pan, inner and outer rocker replacement along with raised driveshaft tunnel, chassis was blasted, etched, primed and painted prior to assembly. Cannot build this car for this. $13,500.00 OBO Price Drop 11/10 NO TRADES. THANKS 580-579-5266 My name is Matt View attachment 4456346
