not a hot rod truck but figured it would be ok here due to the vintage, maybe you need a 4x4 shop truck? ? if I need to delete this listing please let me know and I'll delete it. Originally a Flathead V-8 powered truck, currently has a Yblock 272 or 292, or 312 . not sure but was told it runs, I havent messed with it as I was planning on putting a correct Flathead V-8 engine back in it and I have collected a good running flathead to put in it along with the correct hard to find parts for the 53 truck only parts- Radiator, shroud, front engine mount, 53 only bellhousing including the dust cover etc. asking $5600 as is, very solid truck for restoration. I only know of one other 53 F250 MH truck and its is beautiful, and the same color as this one. It was originally (Meadow Green) which is the color I had planned on painting this one. Has the desirable T-98 Transmission with Synchro's (no double clutching required) and 2 speed Marmon Herrington Transfer case this truck is a project but a solid start, the front axle shafts are out and under the seat as i can see where they have been repaired. the bench seat is not original, and the steering wheel is not original. I am hesitant to sell this truck, I don't need to sell it but I have way to many projects and little time to work on current projects so I've decided I could let this one go to a new home. I have the Utah Title in my name for the truck, the truck came out of Idaho, unfortunatly I don't know any of its past history I have a good running Flathead V-8 Engine with correct bellhousing, front mount and radiator to include with this truck for additional $ if desired. (The Restored Meadow Green truck in the last 2 pictures was my inspiration/dream for this one) More pictures on request.
