Auctions
Sold
Discussion in 'Cars For Sale' started by irisrust65, Sep 20, 2018.
  1. irisrust65
    irisrust65
    from OK
    City: Tulsa
    State: Oklahoma (Boomer!)
    Price: 1800
    Thought I might build this one. As the old saying goes time changes things so someone else needs to do it.
    Clear up to date title.
    Prior to updated tags and title it was last tagged in 65. Title is in my name so it is clear. Does not run and drive.
    Needs a lot of work.
    Last oil change on the door sticker is 1960.
    Built as a drag car sometime in the 60's.
    Put 4 tires on it and pulled it on the trailer. Still rolled easy.
    322 1955 1956 4 BBl Engine. Clear solid core spark plug wires with Rajah Clips. The headers bolt together on the left bank to go around the steering column. Old Wizard Voltage Regulator. 3 Speed Pontiac Trans with an old Foxcraft Shifter. Pontiac Rear End. What look to be very early Traction Master Traction Bars. A pretty nice job when it was built.
    Engine had the bolts out of one valve cover and rockers and springs had dirt dobber nests on them. Cleaned and soaked them with oil. Filled cylinders with tranny fluid/diesel mix.
    Floors are pretty bad. Will need almost complete floor pans. Trunk is pretty solid. Exterior is pretty solid. Has dings and dents and the right rear needs some pulling and straightening. Needs glass. Original seats in the car.
    $1800 for the car and title.
    Additional parts available for additional $.
    Some new parts include: Gas Tank, Straps, Sending Unit, Wiring Harness.
    Also have a set of Buick Finned Valve Covers and a Weiand Tripower setup for it.
    More pictures available.
    Again $1800 for the car.
    PM if interested. Might be able to deliver.
    benchseat4speed and catdad49 like this.
  2. irisrust65
    irisrust65
    from OK
  3. irisrust65
    irisrust65
    from OK
  4. irisrust65
    irisrust65
    from OK
  5. irisrust65
    irisrust65
    from OK
  6. irisrust65
    irisrust65
    from OK
  7. irisrust65
    irisrust65
    from OK
  8. irisrust65
    irisrust65
    from OK
