Hey all, Got a basket case 3100 with a stock 3 speed and I need to identify the correct linkage rods and where they go. Anyone have detail pics at the column and at the trans so I can make sure the levers are on correctly etc? Thanks in advance
If you've got them both I remenber as being pretty ez. I do remember the 2-3 trans arm aimed down so I'd guess the both did. The bolts to hold them in the notches spelled it and the longer one went on the 2-3. As for the steering column the lower one was 2-3 and the upper 1-R. I'd just keep trying. Only could be 4 tries. Good luck.
I would help but I have the top loader SM420. Good luck. Sent from my iPhone using The H.A.M.B. mobile app
Couple of pics from my '51. Been too long to even remember what the 2nd one is. These are just before disassembly, and aren't there anymore.
anyone else? The only rod I have that fits hits the brake pedal. Probably for a passenger car. Or is there anyone local to Lawndale/Gardena/Torrance who has a stocker I can come look at? Thanks.
