1953 Chevrolet 210 “Mild-Kustom”. $11,500 OBO *CLEAN TITLE UNDER MY NAME* - 235 Chevrolet engine - automatic trans - powerglide rearend - Headliner is complete and original with minor tear - Seats are also complete and original - FRESH painted dash and window trims ( painted two months ago METALLIC MANDARIN GOLD ) - Door jams and inner trunk were painted DARK OLIVE METALLIC - NEW (4) 670 firestone tires with 3 1/4 white wall - Molded in lake pipe inserts ( lake pipes unavailable ) - Frenched Headlights - Frenched Tailights - Peaked hood - Frenched Outer-Grill ( needs center grill bar, I have a usable one to go with it ) - Shaved trunk emblems - Shaved hood emblems - Shaved door handles - Shaved gas tank cover ( 64-68 mustang gas tank has been relocated to the inside of the trunk ) - I have a majority of the trim available to go with the car - Front Disc Brakes - Rear drum brakes - NEW 55-57 Chevrolet Disc Drum Dual Power Booster + Master Cylinder relocated to the firewall - 6Volt to 12 Volt conversion has been done and a NEW 110 AMP 3-wire alternator has been added - 3” lower blocks in the back - ( I have the front coil springs that need to be installed ) - ( I have the rear shocks that need to be installed ) - BRAND NEW radiator - BRAND NEW electric cooling fan THE BAD: - Has a broken front windshield that is installed and needs to be replaced. I may have a spare to go with it. - Has two minor rust holes, I’ll send images upon request. - Has a small dent on the rear driver-side quarter panel, needs about an inch of body work to make it straight, I’ll send images upon request. - I drove it for this summer and all of a sudden it started leaking trans fluid even after installing new gaskets, and it doesn’t want to get in any gears. I’ve asked for more opinions and by the sound of it, the transmission might’ve gone bad. Calls preferred: 209-947-3465 $11,500 OBO
