1953 Buick
Discussion in 'The Hokey Ass Message Board' started by loranzo46, Jun 6, 2013.
  1. loranzo46
    loranzo46
    from pa
    Has anyone messed with a 53 Buick and upgraded the lever shocks or know anything about the lever shocks to make them like new. Found rebuilt ones but damn might as well give my kids and house for them.
  2. Orn
    Orn
  3. nali
    nali
    Some keep them as axles , but empty and with a bit of grease, and use regular shocks. Cheaper way I think ..
    If you plan to rebuild them, I don t think there s better explanations anywhere than on Jyrki s site :)
  4. loranzo46
    loranzo46
    from pa
    Yeah I may just figure out a way to add gas shock just gotta fab a bracket. I've seen these customized on the web and a lot throw a different frame under but I don't want all that its just a driver to have some fun in.
  5. Rickybop
    Rickybop
    Yup...a little expensive to have 'em rebuilt or a bit of a job to do it yourself. Mainly just need seals, but you still gotta take 'em apart. Rear ones come off easily, but the front ones are also the pivot for the upper A-arm, and not easily removed or replaced. So install tube-type shocks, eliminate the rear levers and fill the fronts with grease 'cause they need to be lubricated but they won't leak.
  6. Orn
    Orn
    I did exactly what nali and Rickybop mentioned on my 48 and installed grease nipples instead of the fill plug in the shocks and fill them with grease. Here’s some pics of the new shock mounts.
  7. loranzo46
    loranzo46
    from pa
    Thanks for the pics. Now I see how it's done. You have any pics on the front end how the mounts are ?
  8. nali
    nali
  9. nali
    nali
  10. loranzo46
    loranzo46
    from pa
    Thank you for all the links and info. Very helpful with what I gotta do.
  11. Rusty O'Toole
    Rusty O'Toole
    They usually don't wear out but need to be refilled with oil. You can't get the knee action fluid anymore, except from some specialist antique parts places. But ordinary jack oil is just as good, you can get that anywhere.
    Have also heard of using motorcycle fork oil which allows tuning by using different grades of oil.
    Try filling with oil. Drive around a few days and check them again. You may have to fill them 2 or 3 times to work all the air out. Leave some air space in the reservoir. The big problem is when they are worn the oil leaks out the shaft seals.
  12. loranzo46
    loranzo46
    from pa
    Thanks for all the info I greatly appreciate it.
